Question about Kenmore 22062 Top Load Washer
Kenmore 22082 I have codes come up and I need to find out what they mean
These are the codes out of the manual below:
"PF" (Power Failure) flashes
Was the washing cycle interrupted by a power failure? Press
START to continue the cycle from the moment that power
was lost, - OR - Press STOP/CANCEL to clear the display
and completely cancel the cycle.
"FL" (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
• "Er" (Processor Reset Error)
Cycle information was not stored during a power failure.
"LF" (Long Fill) flashes
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
• "CE" (Communications Error) flashes - beeps once
• "Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
• "Or" (Open Relay)
Washeroperation failure. Call for service.
"Sr" (Stuck Relay)
• "LS" (Lid Switch Error) flashes
Is the washer lid open? Close the lid and press START to
continue the cycle.
Is the lid closed? Open and close the lid. Press STOP/
• "SL" (Suds Lock)
Press STOP/CANCEL to clear the display. Drain/Spin load:
restart cycle. Do not add detergent. Use cold water.
• "dt" (Diagnostic Tests)
For service diagnostics only. Press STOP/CANCEL to clear
the display.
"ob" (Off Balance)
Is the load unbalanced? Redistribute the load. Close lid and
press START.
Posted on Nov 14, 2008
OL on my washing machine
Posted on Oct 30, 2008
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
Jan 18, 2017 | Kenmore Humidifiers
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    I have a kenmore elite oven what does an error code F-3 mean
    Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
    http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
    GENE
    Oct 03, 2011 | Kenmore Ovens
    Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
    The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
    Gene
    Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
    Kenmore 790 range with f1 code. Waht does this
    it means probibly the EOC has failed and needs replacing that is a pcb called the electronic oven control
    Jan 28, 2010 | Kitchen Ranges
    My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
    Oct 07, 2009 | Kenmore Microwave Ovens
    Kenmore washer has a error code of hc
    You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
    Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Kenmore dryer codes
    That means you are in the automatic cycle, or what is used to mean. Pretty sure it still means that. Jim
    Aug 14, 2007 | Kenmore 659 Electric Dryer
    Kenmore 22062 Top Load Washer Logo
    858 people viewed this question
    Sal De GO PATS
    fordexpert
    Ed Mac
