Question about Frigidaire FGF326AS Gas Kitchen Range
When setting the oven it only goes to F 1 and beeps constantly
  • Frigidaire Master
  • 1,711 Answers
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Posted on Oct 04, 2010
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
My Kenmore wall oven has a code F7 and is constantly beeping. What does this indicate?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore Ovens
After broiling steaks, f10 appeared on screen and constant beeping since. 1-2 hrs now. turned off electricity and keeps beeping.
Press the Stop/Clear button. If that doesn't work, press it and hold for 3 seconds. If you get a fault code, something is broken. If it is associated with broiling, the first thing I would check is the broiler temperature sensor. Is there a buildup of grease on the ceiling of the oven?
Jan 10, 2011 | Kenmore 47783 Electric Single Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
How to stop the beeper and reset the "code' light on panel?
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it, and please reply back with your model number so we can help you.
FOR ADDITIONAL SET-UP OR OPERATING ASSISTANCE
PLEASE CALL: 1-800-898-9020
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Emerson MW8107WA Microwave Oven
F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Aug 29, 2006 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire FGF326AS Gas Kitchen Range Logo
122 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
