Question about GE JKS05 Electric Single Oven
I have an old GE Wall Oven, Model JKP36GOD2BG. I do not know how to operate the self cleaning function. Can you provide step-by-step instructions?
SOURCE: wall mounted self clean convection oven by Frigedaire!
Unplug it or turn off the breaker
Posted on Apr 19, 2008
SOURCE: Elitech 1300W convection oven: How to set it for self cleaning
Hi
If you watch the advert for the Nuwave or Flavorwave they set the machine to defrost setting.
Put water in and a bit of washing up liquid and put on for about 10 min.
Posted on Dec 09, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
cactus bob
  • 267 Answers
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Posted on Jan 15, 2009
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
Need to know how to operate the ''self-cleaning'' function of the GE TrueTemp Oven.
Take the chrome racks out of the oven
make sure oven is COLD
move lever on door to the right
turn dial to CLEAN display should say 4 hours, but I've found 3 hours is plenty, reduce by touching Cook Time
YOU WON'T BE ABLE TO OPEN THE DOOR FOR 3-4 HOURS.
Jan 19, 2010 | GE Ovens
PURCHASED NEW GE WB27T10327 OVEN CONTROL TORISAN ERCB3 DID NOT HAVE INSTRUCTIONS FOR A NON SELF CLEANING OVEN. CAN YOU HELP? JERRY
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
How do I start the clean cycle
The "S" in the model number stands for standard clean oven (vs. self clean), so unfortunately, you will have to use a can of Easy Off or similar oven cleaner.
May 07, 2009 | GE 24" Built-in Single Electric Wall Oven...
Getting error code F10 on Kenmore model 47889603 wall oven
Leaving the breaker off for the time I was at work (about 9 hours) seems to have cleared the problem. May have just been an abberation and not an actual problem with the appliance. Since the first step with most electronics that develop a fault of some type is to power down for a while then power back up to reset the electronics, I decided to see if that would do it and it did. Thanks for having a site to go to for assistance, though!!!! -Mike-
Dec 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE JKS05 Electric Single Oven Logo
190 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
