Question about Apple MacBook Laptop Computer Mac Notebook
My Macbook told me that I had to shut it down while I was working, which I did. Now when I try to turn it back on all that comes up is a small folder in the middle of a blank screen that changes between a smiley face and a question mark? The computer will not go past this phase. How do/can I solve this problem?
    Guru:
  • 206 Answers
Thanks for contacting Fixya Support, I am glad to assist.
What you need to do is perform an SMC Reset in order to allow your Macbook to start back up correctly to the desktop.
Here are the procedures for an SMC Reset:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the Macbook's
battery.
• Press and hold the power button for 5 seconds and then
release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the Macbook
If this does not work, then try this procedure:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps.
Regards,
-Mactechtrainer
Posted on Sep 17, 2010
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
My MacBook wont charge
So does the organge light still not come on now? If it doesn't try a different charger first. If that fails, your DC-Jack module or logic board may need to be replaced. There are detailed instructions on how to do the restore online. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jun 19, 2010 | Apple iBook Mac Notebook
Macbook restarts when i shut it down
Try going into Utilities folder and open Disk Utility and repair disk permissions. That fixes a number of bizarre issues in Mac.
Sep 09, 2009 | Apple MacBook Air
Before my computer use to get really hot and then my computer use to shut down. I think there is a problem with the fan. Today when I switched it on the apple logo will come with the sound when it starts....
there have been problems with MacBooks suddenly shutting down since the first Intel based MacBooks were made. It is called RSS. (Rapid Shut Down Syndrome). The cause of which I have learned in the following excerpt.
Since isolating the heatsink as the cause of the MacBook’s Rapid Sudden Shutdown (RSS), readers have isolated the specific part of the heatsink that is causing the problem, is actually the CPU thermometer itself. Essentially, the heatsink can expand during use, and comes into contact with the lead from the thermometer’s sensor cable. A short circuit results, and the SMC pulls the plug. Once the system cools down, the heatsink resides and the contact is broken. This also explains why sometimes you cannot immediately power the MacBook back on. The heatsink is still in contact with the metal lead.
Apple’s solution to this is to realign the location of the thermometer and cabling on the heatsink so that it does not short circuit. That is why the new heatsink is necessary. In the view of this writer, it warrants a public recall. Any user can produce easily the scenario that causes the MacBook to crash, even with pre-installed applications such as iLife.
My 2 cents,
Thanks
Fame !
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
Oct 05, 2008 | Apple MacBook Pro PC Notebook
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
Apple MacBook Laptop Computer  Mac Notebook Logo
238 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
