Question about Jensen Car Audio & Video
Put a new battery in my car and now my jensen pcd163 will not work. I checked the fuse and it isn't blown. Help!
  • 37 Answers
See if there's a reset button, usually behind the faceplate. Try that.
Posted on Sep 17, 2010
Blown speaker
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
Jul 10, 2013 | Jensen JTA460 Turntable
Hey I have a CRf 230f 2009 model just wondering why my bike won't start we found a blown fuse near the battery box and we have put another fuse in it but it still Won't start unless we jump start...
That blown fuse is most likely attached to a round thing with two big terminals on the top. That is your starter solenoid, it is possible that, that has failed.
Although it if starts off a jump start then it might be your regulator that is junk and isn't allowing your bike to fully charge your battery.
Sep 11, 2011 | Honda CRF 230 F Motorcycles
Daughter called me ..car wont start. checked battery at Autozone...it is good. someone stopped to help them and bang on startere and it starts up. Bad starter. Starter replaced. Next day daughter...
it sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
Sep 02, 2011 | 2000 Oldsmobile Intrigue
I have Jensen cd player but I wanna hook up a amp and it doesnt work even with the RCA plugs isn't sending signals?
Have you checked all the power wires and fuses for the amp. Have you made sure to connect the remote turn on lead properly. There are a number of things. On your next post, go through the steps of your amp install.
Aug 24, 2011 | Jensen Car Audio & Video
A piece of metal fell of my phone charger into the cig lighter and caused a spark. I pulled over and the radio, odometer and lights would not work. Then after the car was put in park, i could not get it...
check for blown fuses in fuse boxes under dash on left & under hood.check for a blown 'fusible link' a wire leading from battery + terminal to the electrical box near the battery.a fusible link is a wire designed to 'melt' in case of a short.outside of link will appear blistered,and a new one needs to be soldered in it's place.
Oct 13, 2009 | 2003 Toyota Corolla
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
Jensen VM9312 Stopped working
MAKE SURE U CHECK THE FUSES UNDER THE HOOD.
Mar 31, 2009 | Jensen's VM9312 Car DVD Player
Jensen xa2150 amplifier
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Dec 18, 2007 | Jensen XA2150 Car Audio Amplifier
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
