Any time I turn on my Printer Ricoh Aficio SP C811Dn, I get the error code Sc202 on the panel..
  • pennpp1 Sep 17, 2010
    Over here I have no Ricoh specialist available. The reason why I'm in touch with to solve the problem. Would you tell me how to get out of this matter.
    For your record I want to let you know that this unit is a brand new one with less than 2000 pages printed.
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. make sure there is no other conflicting softwares in the pc specially recently downloaded programs. If so uninstall them too. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Now make a test to see if the PC commands the printer. If there is no response, check the head assembly/ ink carriage to be struck or out of alignment. Check for possible realignment of any of these mechanical problems., jammed roller or head drive.
If not check the power supply unit for sub voltages to the main board. If all these are fine the main board can be faulty.
Posted on Sep 17, 2010
  • 942 Answers
This particular error pertains with the polygon motor of the machine. The reason being the that the machine is defective or the cable running to it is defective , it is a herculian or a difficult task getting to that motor so i strongly suggest you get a professional expert to solve this one for you .
Posted on Sep 16, 2010
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
How do I factory reset my Ricoh Aficio SP C811DN?
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
Jul 17, 2014 | Ricoh Aficio SP C811DN Laser Printer
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Apr 03, 2014 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
553 is:
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1
second.
�� Defective PSU
�� Defective IOB
�� Defective EGB
These codes related to the fuser a designed to prevent a fire
I would recommend haveing a tech look at it
Nov 08, 2009 | Ricoh Aficio SP C811DN-DL Printer
111 people viewed this question
jasbo
jasbo
