Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error E 4 54043e02 "Can Not Record On This Disc"
    Problem Solver:
  • 9 Answers
I was getting the "can not record to this disc" error on the Magavox DVD Recorder and a Memorex lens cleaner solved the problem.
Posted on Dec 01, 2010
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
My camera is displaying a message that states "movie recording disabled" when I try t record something. I have no idea how it got there so I have no idea how to inable it again. Any suggestions?
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
NOTE: If the error is still displayed after performing these troubleshooting steps, service will be required .
Jul 31, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Invalid disc prompt,whenever i install a disc
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Jan 09, 2008 | KLH CDR2000 2-Disc CD Recorder
Optical error
Your laser is failing. There is a test mode sequence you can try to re-calibrate it but to be honest it's the beginning of the end. I can supply replacement laser assemblies depending on where you are in the world or I can email you the service manual so you can try adjusting it yourself. Email me via ebay - fluffcat1
Audio cdrw's are still freely available in the UK.
Dec 28, 2007 | Philips CDR775 2-Disc CD Recorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
1,092 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
