Question about Sony HVL-F32X TTL Flash
Sony hvl-f32x I turn on the flash with new batteries, it flashes the word "connection" the orange ready light flashes and then it just shows red light and err flashes... I hcan't make it do anything now. Please help!!
  • 1 more comment
  • Anonymous Jun 24, 2008
    Have the same problem as Angelab76, since early 2008, and have not found a solution yet. I use the flash with a Sony DSC F-828 camera exclusively.
  • ajnayar65 Aug 27, 2008
    On turning the flash on, the orange light stays on but the flash don't work with the camera. Instead the camera still keeps using the inbuilt flash. The Hot shoe is turned off in the camera setup menu.. On pressing any button on the flash, the word connections flashes. No other display on the flash screen.
  • victorR1 Dec 25, 2008
    I also have the same problem with my flash and DSC-R1. Please help!!
Arpi
  • 326 Answers
SOURCE: Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 24, 2007
  • 231 Answers
SOURCE: My flash will not work and i have this flashing...
common problem on this type of model.Possible might need new flash assy and or flash data changed after installing new flash assembly ..
Posted on Nov 28, 2007
SOURCE: Sony A100 - Buttons won't work
This sounds odd, I know, but I found a solution that worked for me. I had exactly the same problem: picture taking was wonky, menu button, playback button wouldn't work. It would do this immediately upon starting up, every time.
What worked was when I adjusted the "exposure" by holding the +/- button and turning the little dial near the shutter button. It makes absolutely no sense, but somehow it suddenly started working perfectly again. And it hasn't glitched up again yet.
Hope it works for you, too.
Posted on Dec 18, 2008
Rammsteins
  • 300 Answers
SOURCE: I KEEP GETTING ERROR E9101 PLUS ORANGE LIGHT KEEPS
Hi!
It's flash problem - could be a dead flash fuse or flash board. You should contact your local Sony service center or if they ask too much, you can contact me at toms.rammsteins@gmail.com. If you have a multimeter and you're ready to open it and test the fuse, contact me.
I work in a Sony service center.
Tom
Posted on Jul 28, 2009
SOURCE: when turning on power lcd says acess ,lens opens
I had the same problem. Your focus is stuck.
Try to free the focus from whatever (sand, dust, etc.) by hitting the camera. Start gentle, and if it doesn't work, hit it hard...the DSC-W30 is very rugged , that was my experience!
Greetings from Germany and good luck!
Posted on Aug 07, 2009
I have been putting new expensive batteries in but is still spends a minute flashing orrange then flashes a red light and says "error" as if my batteries are dead??
Sep 11, 2011 | Sony HVL-F32X TTL Flash
Sony HVL-F32X manual
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa
Sep 06, 2010 | Sony HVL-F32X TTL Flash
Ihave a sony flash DSCHVL-F32X whch I use on my Sony DSC-828. This has never given trouble but it now seems to refuse to connect to the camera
Try resetting the camera?
Other items you might have missed:
Fresh batteries in the flash..inserted the right way.
Is the flash indicating an error code? if so it could be bad connection between clash and camera.. Is external flash selected in the menu?
Jun 18, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Hot shoe plastic section broke on flash unit
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Jun 17, 2009 | Sony HVL-F32X TTL Flash
Still flash
Sorry, no light, no flash! It IS, however, compatible with the Sony HVL-HFL1 Combination Light and Flash unit - MSRP $149.99, but it's online for as cheap as $106 through Amazon. Flash range is 5m, and it's powered off the camera battery, so there's no in-flash battery to worry about...
Please rate this solution if you found it helpful!! Thanks, and good luck!!
May 12, 2009 | Sony Handycam® DCRSR45 HDD Camcorder
Sony hvl-f32x
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Then pull the pieces apart gently. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  6. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  7. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
  8. Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Hope this helps!
Feb 05, 2009 | Sony HVL-F32X TTL Flash
Shutter button delay
The flash need to be fully charged before it would fire the shot.
In case the battery is old and supply power is not enough to boost the flash, it will await until the orange LED of flash indicator is no longer blinking, means ready to take picture with flash light.
Replace the new full battery will be better and faster to take shot with flash enable.
Jan 01, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Can;t turn the tightening knob to mount the flash? Maybe the pin lock?
I'M UNCLEAR AS TO WHETHER YOUR ISSUE IS WITH THE LOCKING PIN OR THE COLLAR. STANDARD FLASHES, WITHOUT A "LOCKING PIN", A PAIR OF CHANNEL LOCK PLIERS CAN BE USED, AFTER WRAPPING THE JAWS WITH SOMETHING GIVING, LIKE ELECTRICAL TAPE, OR WRAPPED RUBBER BANDS. THE COLLAR CAN USUALLY BE LOOSENED IN THIS MANNER, IF IT HAS "BOTTOMED OUT" OR GOTTEN STUCK ON ONE END OR THE OTHER OF THE THREADED FOOT SUPPORT. IF YOUR ISSUE IS WITH A "STUCK PIN" THEN PLEASE DISREGARD THIS ADVICE.
Sep 25, 2008 | Sony HVL-F32X TTL Flash
Sony HVL-F32X TTL Flash Logo
175 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
