Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
Usb problem It used to work fine, but now my PC is not able to identify the USB Drive. !! I already have some important files on it.
  • babyvalkyrie May 19, 2008
    me too! i have a portable samsung hard drive that is no longer being recognized when i plug it into my pc. what should i do?
Question Just brought NEW HDD753UJ on the sticker reads as samsungS13UJDWQ328674 what is it A rebuild in runs only WIN98 same thing wont recognise it has been plugged in light is on on case but no flickering only showed 698 total KB from new off eBay thanks longgrazz@gmail.com
Posted on Jun 14, 2008
    Scholar:
  • 119 Answers
No fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
Posted on May 19, 2008
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
Bytecc BT-300 USB 2.0 drive mate problem : I am a PC user with WinXP O/S. My BT-300 worked fine when used along with 2.5 in laptop hard disk (power cable connected to drive mate). On the other hand, I am...
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Feb 22, 2010 | BYTECC USB2.0 to IDE Adapter Kit...
I want to transfer all sate data from my old laptop to my new PC, I have already installed the hardware on the new PC
Sage has an EXPORT function that you can use to transfer data.
You could also copy the daily files from the storage folder to a USB drive
O the new machine use the IMPORT function to import a backup of the files or use the folder options to get data from the USB drive to set up a new company profile which would use your old data to set up a new copy of SAGE with your exisying information.
The prefered option is IMPORT / EXPORT
Feb 21, 2010 | Sage Instant Accounts 8.0 (013604ug)
Drive does not show up on my computer. How do i see the drive. It is plugged into power and to a usb port
Is the drive already formatted? Or does it contain files already? Most probably, you just need to assign a drive letter to your usb drive.
If you are using Windows, right click on My Computer and then click Manage. Under Storage, click Disk Management. Locate your USB drive ( you can identify if its your drive by checking on the properties. Just right click on the drive and click Properties.
To change or assign a drive letter, right click on your USB drive and then choose Change Drive letter and Paths. You have the option to Add, Change.
Jan 07, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
16 bit 44.1khz monaural wav format files
I'll assume first that you have wav files on your PC that you'd like to import into your 2488 to use as percussion tracks.
You'll have to convert those files on the PC first into mono wav files. The 2488 can handle 16 or 24 bit so the bitrate shouldn't really be a problem. (It will also automatically truncate a larger bitrate down, but you should really dither the files rather than let them truncate... another topic).
You can use Audacity (free) to convert stereo wav files to mono wav (audacity will also dither for you).
Once your files are converted and saved on the PC, on the 2488 open the USB connection from the DISK menu. (This assumes you already have a usb cable connected between your PC and your 2488.) You will see a device appear on your filelist called HD_2488 or something like that with a drive letter. Copy your mono wav files into the WAV directory on the 2488 USB device.
Then on the 2488 press 'exit' to close the USB and from the WAV IN/OUT menu choose 'USB import'. You should see the WAV files listed. If those files are not mono waves you won't even see them listed. Select the file(s) and press enter to import. You'll be prompted to choose which track to import them to.
That's pretty much it.
bd.
Feb 20, 2009 | Tascam 2488 Portastudio Multitrack...
All of a sudden my computer dosent recognise the USB Drive ( PQI - U230 )
at this point i would take the usb drive apart, you should see a regular hard drive in it. if so just set your jumper settings and insert it to your computer. if you still got problems then your drive has crashes on you. you can try at this point some hard drive recovery tools found across the net.
if the drive is too small to plug in then you need to get an adapter usually found at ebay. if this is a pen drive then i would take it out of the case then look for and solder the usb connector as this is the first bad spot to go. anyways, if its a hard drive and works in computer, i would check power supply goin to the use drive, if its good then i would contact the company that made it maybe they will replace the unit. or just buy another one. copy info back over to the new drive. or get a drive just like it and swap them out.
good luck.
Apr 22, 2008 | Fantom Drives 120 GB Hard Drive
USB Flash Drive Problem
Instead of trying to access them when they do come up, try shifting them or making a backup.
Mar 13, 2008 | Computers & Internet
Usb drive is not deteded when plug into PC
Dear sir I am using kingston 2 GB USB pen drive it is suddenly not detected with my HCL leaptop. Plz kindly help me
Jul 01, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
302 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
