Question about Canon Pixma MP270 All-in-One InkJet Printer
The error code is U53 and it reads, The ink cartridge cannot be recognized.
SOURCE: MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
SOURCE: cannot recognize ink cartridge
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Posted on Dec 03, 2008
  • 4090 Answers
SOURCE: Ink cartridge error code UO53
not a genuine cartridge
Posted on Aug 19, 2009
CaptainHawk1
  • 345 Answers
SOURCE: epson rx595 cannot recognize ink cartridge
Just had this happen to me. Turned it off, turned it back on... nothing. In/out with the cartridge several times and when I blew on the contacts of the printer (where the little microchio on the cartridge touches) it finally worked. Did the blowing on the contacts help? Maybe, but more likely is that the it was just repeatedly trying to d oit before the machine figured it out.
Posted on Sep 26, 2009
  • 284 Answers
SOURCE: Canon PIXMA MP140 error code E
Replace with genuine cartridges is the best policy.
Posted on May 31, 2010
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
When trying to print an error came up that read " Cannot recognize ink cartridges"
You may have bought the wrong ink cartridge. It is suggested that you use the code 68 or 69 catridges. If you are using these and there is still a problem try gently cleaning the copper on the back of the cartridge (use a tissue, you must take the cartridge out to do this.) If that still doesnt work then take it back to the place to which you bought it
Mar 02, 2011 | Epson CX8400 All-In-One InkJet Printer
Canon Pixma MP210 will not recognize high yield PG-50 & CL-51 cartridges.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
Dec 24, 2010 | Canon Office Equipment & Supplies
Doesn't recognize the color ink cartridge
Good day!Your cartridge is the problem..even if its new or original if the printer never detected or sense your cartridge's presence..then that error will appear..
So,try to change a while or borrow if you have friends there just for reading or proven the problem..
mastergani
Apr 03, 2010 | Olivetti wireless All-In-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Stylus DX 8400
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
E5 and 2,114,0 errors on Canon MP160
I got this Error 2,114,0 with my MP210 and none of the above fixes worked. This is how I have got it working again: Press and hold the maintenance (picure of spanner and screw driver) button and the reset button ( Inverted red triangle) together for five seconds or more. The flashing error code 1 and 6 will then stop flashing and replaced by a print copy no 1. The printer/scanner is reset and the scanner works.
Feb 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP270 All-in-One InkJet Printer Logo
243 people viewed this question
old marine
old marine
