I have a Kool Sound CDS-220 twin cd DJ mix unit but the output volume is very low when put through the amp, even with all the volume dials turned up. The headphone port gives plenty sound and both cd players play as they should. The master output knob crackles slightly and sometimes trips the amp so it doesn't blow. The LED volume display reacts when this mater volume dial is turned then disappears when you stop turning it. Just bought this second hand but it maybe simple to fix?
  • 4234 Answers
SOURCE: Purchased your A/V reciever NS-R5101
This type of volume control is often called an encoder. Basically it is a control for an electronic volume control chip. Rather than a vairable resistor like the "old fashioned" volume controls, this one basically is a rotary on/off switch. As you turn it the internal fingers pass over copper bars causing quick on/off sequences. These are interpreted as vol up and vol down.
Realise that this is an over simplification, but is essentially how it works. Your unit is fine.
Dan
Posted on Jul 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Posted on Mar 05, 2010
  • 122 Answers
SOURCE: 1974 FENDER TWIN REVERB HAS
check the speakers try to connect another speaker.then check the output transformer and the resistances at the bottom of the 6L6 tubes.then check the bases of output tubes and the output tubes matching trimmer if your amp have it.then check change the volume pot.then check the ceramic capacitor i n the input of the last 12ax7 tube in the power amp input.
Posted on Jun 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi there, our amp is giving us very low sound
I'd look at the front panel for the Mute Button and the Mute Indicator, but turn the volume down for any further investigations. If you can't hera the sound at 1/2 volume, it ain't there. No sense risking a sudden volume surge that will kill your speakers when you finally find the problem.
http://www.retrevo.com/support/Harman-Kardon-HK3270-Receivers-manual/id/386bh430/t/2/
Also check the T-Mon Indicator. If it;s on you have the Tape selcted for listening instead of a source.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
Posted on Dec 26, 2010
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
Why has the sound / volume stopped working
It sounds like the output device may have failed. Check the manual it may explain it.
Nov 28, 2014 | Sony Audio Players & Recorders
I have 2 Mtx PA speakers with Brand new Stereo cables plugged into the back of them then the other end is going to my amp. But When i turn on my dj program and try to test them It is extremely quiet. Even...
This is a car stereo amp or DJ Amps and speaker set up? I think your question is in the wrong area. It sounds like you have something switched in the wrong position like monitor or record possibly using the wrong outputs or incorrectly figured signal routing. Possibly check the amp out signal selector on the mixing board? This question could be answered much better by a DJ in one of the many problem solving forums they have at other web sites. I have visited a number of them researching equipment I was selling. Just Google DJ Mixers forums.
Aug 16, 2013 | Car Audio & Video
Trying to record music from my dj equipment not sure how to connect
out put from the dj stuff to the input lines on the amp your using to record on, once the CD or tape, or whatever your recording onto, is set to record, it should pick it right up , now if your doing all of this off your DJ equipment everything that's used, from record players, to CD to tape, will be run through the main amp your using, if the selection switch is set to whatever, you should be able to just turn on the unit your recording to, and it will pick it up , everything leading to the main amp will be plugged into, a line in, and some, ( tape player ) will also have a line out, ( so should the cd player if its a recordable one, which in turn would be supplying the lines output to each unit .
Jul 25, 2011 | Audio Players & Recorders
I turn it on and at the volume set @ U or straight up(midway) nothing comes out. if you turn it all the way up of course you get alot of buzz and barely get any sound from a mic or mixer signal,etc. could...
Make sure you are using BALANCED line to this... XLR connections boyh ends. Make sure ALL interconnected devices are powered from the same receptacle or power conditioner. Test your cables... they do go bad. This unit REQUIRES line level input. Do NOT expect a mic to drive it directely. Make sure your mixer uses the XLR outputs and is powered from the same receptacle, even if you have to run an extension cord to it. This is a bi-amped speaker so there are independent amps for high and lows. With nothing out and known good in there is very little electronics before the signal is split to the separate amps. At line level, your volume control should probably be about 2 o'clock with the EQ's straight up flat.
Apr 25, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
42 people viewed this question
 Grubhead
Grubhead
