Back to:
Tags:
Danby DPAC8099 Air Conditioner
Danby DPAC 8099 Moisture Removal problem
posted by beenframed on May 17, 2008
Unit seems to cool fine and work in all other aspects, except there is no moisture being removed. It used to fill the internal tank about once per day under normal usage, but now there is no water at all going into the tank. Is there a specific part or some service that I can perform that will restore this function? Kurt
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
22yooper
Rank:Guru Guru
Rating: 86%, 451 votes
If the dew point of the air in your place of operation is low you will not get moisture out of the air. Generally when the unit is first used it lowers the indoor humidity and you get a lot of moisture. Once things settle out the amount of moisture will decrease.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Danby DPAC 8099 Moisture Removal problem:
I don't want to Accept this solution
Can you Help with these Air Conditioners problems?
Air Conditioners
Smeg gas hob mod PGF 75SC...Two electronic ignitors fail...
Air Conditioners
my hampton fan remote does not work properly the light...
Air Conditioners
modellan121hnp everything comes on except fan evaporater
i recently purchased a danby dpac8099 at a garage sale. It...
someone gave us this air conditioner can i get set up...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
