Question about 1995-1997 Yukon Ignition Starter Alarm Switch
THE CRANK FUSE KEEPS BLOWING WHEN START MODE IS APPLIED TO SWITCH. CHECKED WIRING FROM FIRE WALL TO STARTER , AND IT IS COMPLETE (NO SHORTS OR BURNS...IS INTACTED). THINKING THE IGN SWITCH MY BE BAD! WHAT ARE YOUR THOUGHTS?
emissionwiz
  • 75814 Answers
SOURCE: shuts off while driving. no fuel pressure. pcm fuse blows/ fuel pump relay inserted.
Sounds like the fuel pump is shorted.
Posted on Nov 03, 2008
  • 85 Answers
SOURCE: truck wont start keeps blowing the ecm batt fuse
You have a short (bear wire) somewhere. Trace the wire and find it.
Have a great evening
Posted on May 01, 2009
  • 205 Answers
SOURCE: 97 GMC 6.5 Diesel ,40 amp ignition fuse under the
have your starter tested at your local auto parts store to see if it's drawing to much current
Posted on Oct 20, 2009
rsst
  • 175 Answers
SOURCE: Blower on heater works sometimes, sometimes it
Sounds like the blower resistor. It will either be located in the engine compartment outside the motor or inside the vehicle inside the blower motor cover. It could also as well be selector switch
Posted on Dec 08, 2009
dttech
  • 4803 Answers
SOURCE: Recently got remote starter installed (not by
GM has had more that their fair share of transfer case problems. I have also seen may problems caused by addition of aftermarket equipment - especially remote starters. There is a good chance that you have a damaged transfer case, but if an electrical problem was the root cause of the damage, you will only destroy a new transfer case if the electrical problem is not resolved. If the mechanic that you are going to does not have the proper equipment and/or information to diagnose your transfer case control circuits, you should consider getting a second opinion from the dealer before buying a new transfer case. I currently work in an aftermarket shop. There are several of the GM 4 wheel drive systems where the manufacturer has not released the information necessary for an aftermarket shop to properly diagnose and repair the system. Some mechanics are simply to proud to say "I can't" or "I don't know".
Posted on Jan 22, 2011
Testimonial: "Thank you so much for your time and opinion."
Fuse s under hood keeps blowing. It is the inj/coil fuse
Try jumping the starter with the key on. If it doesn't blow. Check the start wire for chafing and grounding out. You can pull the starter relay, Try to start it, see if it blows,yes, it is between the fuse panel and fuel pump. no. Put it in and pull the fuel pump relay. Start it. If it blows, then it is some where between the fuse panel and starter. If you have one of those intelligent fuse panels, it could be that also. You can have the codes read for it. But it takes a scanner, not a code reader.
Jul 09, 2016 | 2004 Chrysler Concorde
50A IGN Starter SW/ Starter fuse blows every time I start the vehicle
Run a jumper from the fuse connection to the starter
Nov 13, 2015 | 1998 Dodge Durango
I have a 1999 dodge avenger that keeps blowing the 30amp engine fuse under the hood it only blows the fuse when I crank the ignition checked all the words not sure where to look anymore any suggestion's
If it just keeps blowing it could either be a bad ground somewhere or theres to much power getting pushed to it for some reason when u start it, blowing the fuse
Jan 03, 2015 | Cars & Trucks
Ok well I put in a brand new starter because my crank sensor keeps blowing and thinking I fixed the problem long behold I keep blowing my crank fuse when I try starting the truck I don't know wear to start
No, year make or model. But if you blow the crank fuse, it is between the starter and the ignition switch. Could be the switch, but most likely the wire. At the relay there are four pins. 30 is B+ all the time, 87 is to the starter. 85 and 86 can be switched. But one is B+ with the key in start position, the other goes to the ECM, this would be ground.. Since you're blowing the fuse, you need to find the short to ground. this would be the 85 and 86 wires.
Oct 26, 2014 | Cars & Trucks
My 1999 Dogde Stratus 2.4 cyl. keeps blowing the fuse that makes the car start. Replacing the fuse is becming costly and is annoying. What might be the reason this is happening?
if you can get to a parts store have them test the amperage drain of the starter while cranking..if its too high.. replace it..after a while the starter brushes get worn to the point where they cover more armature conacts than they should and will draw up to double what is normal for that car.. also if its not mounted right it will drag.. using way more power to work..see what happens and repost findings..otherwise you may need a hevy circiut breaker in place of that fuse..be aware of any smoking wires and potential fire hazard..
Dec 09, 2013 | 1999 Dodge Stratus
Fuses keep blowing in mower,put aluminum foil around the fuse now it wont start back,what happend?
You had a short..you ether melted the wire or burned up the starter or switch...need to try putting direct voltage to the starter and to ground and see if it turns.if not bad".try putting a screw driver or jumper across the selonoid poles if it clicks and turns the starter the wire to the starter is ok if not sure is burnt or melted .Check for burnt switch and or wires..never do the aluminum truck..will do damage or cause a fire..good luck
Aug 09, 2013 | Briggs & Stratton Garden
95 ford mustang starter fuse keeps blowing. what should i do?
have you checked that the starter itself has not been grounded out (short in the wiring?)
The chances are this is what is causing your problem, start at the starter motor & follow the wires, check every single one, if you have a bare section that comes in contact with the body or anything else metal it will ground out that wire & cause the fuse to blow every single time even if you were to double the fuse resistance I.E. if the fuse is a 20 & you put in a 40 it will still blow - that last part is ill advice - never put a higher amperage fuse in a socket that was intended for a lower amperage fuse - it could cause a fire & serious injury, check all your wiring from the starter you have a short in the system somewhere it's just a pain in the a
4rse locating it
Sep 21, 2012 | 1995 Ford Mustang
Starter relay shorts out when I try to start my bike
I guess define shorts out....It melts, it blows fuse. I guess the best way to start is to remove relay and find the wire from the relay socket that operates the starter and apply 12volts. with a fused jumper wire. if the fuse blows than there its either a bad starter or a short to ground on the wire going to the starter. if it turns over fine, then there is a problem from the starter switch to the relay or wiring at the relay box.
Jul 19, 2010 | 1983 Honda GL 1100 Aspencade Gold Wing
98 Ford F150 4.2 Liter Engine will not crank keeps blowing fuse #21 (15amp) as soon as I turn the ignition key. Was running fine just stopped to gas up and it wouldn't crank. Jumped the posts on the...
Sounds like there's a grounded wire somewhere between the ignition switch and the solenoid. When you bypass the switch with the screwdriver you don't ground out the line, but with the switch the ground shorts the circuit, blows the fuse, and then won't start the engine.
Apr 18, 2010 | 1998 Ford F150 Regular Cab
Have Exmark 52 LazerZ with Kohler ch25 engine. Engine stalled in heavy grass. Tried to re-start; engine turned over several times at lower RPM but stalled almost immediatly (PTO switch disengaged &...
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Jul 16, 2009 | Ford Tractor 8n Front Emblem
1995-1997  Yukon Ignition Starter Alarm Switch Logo
128 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
