Question about Peg Perego John Deere Gator HPX Ride on Toy
My gator will work in reverse but not either foward gears please help
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Posted on Jun 13, 2012
5 Suggested Answers
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 96 Answers
SOURCE: Gator wont go in reverse.
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain the problem with the vehicle, they seem to know a lot about them.
Hope this helps.
Posted on May 05, 2011
  • 24 Answers
SOURCE: the gator would only go into high gear. No
Yep. Its either a burnt out motor (the one that isnt spnning) or the connectors under the gearstick need cleaning, or check the wiring on one motor. It works by putting the motors in parallel for high, and series for low - and if the series has a break anywhere - nothing runs. If you need a motor - visit http://www.wackywheelers.com/shop
Posted on Sep 23, 2011
My John Deere gator ride for kids will go in reverse but will not go foward. What is the problem?
either a bad shifter switch or a bad motor, do both of the wheels spin in reverse?
Jul 20, 2012 | Toys
Gator wont go in reverse. It will go in both foward gears.
Hope this helps.
May 05, 2011 | Peg Perego John Deere Gator HPX
John deer gator goes foward in the reverse position and reverse in the foward positions.
you just need to switch the polarity on the motors swap the two wires around
Feb 25, 2011 | Peg Perego John Deere Gator HPX
John Deere Gator HPX: Reverse does not work...
does 1st gear work? do both wheels spin in all of the gears?
May 06, 2010 | Peg Perego John Deere Gator HPX
My gator 4x2 makes a loud rubbing sound when i hit the brakes
remove the wheels & inspect the brakes as the pads or shoes are most likely worn out!
Cheers rob
Aug 02, 2009 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
46 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
