Question about Dometic Rooftop RV Air Conditioner
The unit does not stay running but I noticed that the fan motor is not comming on but I can free spin the motor. Is the motor the problem or does the unit run then the motor kicks on after a period of time?
  • 674 Answers
It could be the motor, but I would make sure it's getting power first. Then I would check the capacitor. Turn the power off before checking the capacitor. If the capacitor is good, use an ohmmeter to check out the fan motor.
Posted on Sep 17, 2010
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Coleman Rooftop AC fan stops after 7 or 8 minutes of running. Will turn on again after about 10 minutes on its own.
Remove green (fan run) wire from thermostat, and connect to red wire (power) and see if fan runs, and if it will stay running. That will by-pass thermostat to see if it is problem. If it continues to run, thermostat is problem. If that doesn't cure it, I'd remove cover up top and with power off at circuit breaker, blow compressed air in to motor air holes to make sure it's getting proper air for cooling, as well look for small plastic plug on housing where oil can be added ( few drops) to lubricate motor. Leave cover off and try fan to see if that may help. If at all possible, a clamp on amp meter will confirm if motor or relay is at fault if none of these suggestions help. If amp draw at motor too much, motor may be seizing when warmed up from running. test draw when first started and after running for amount of time that it usually quits, and if noticeable difference, motor is seizing and needs replace. You can also test amp draw at main 120v feed wiring with unit just in fan mode.
Sep 13, 2012 | Coleman Heating & Cooling
FA4B blower assembly noise
It is possible that the actual fins have separated from the hub. Hold the shaft of the motor (as to stop it from spinning) and the try to spin the fins. You then may notice the welds are broken. Could just be a bad motor, could be just the wheel. Good Luck!!
Aug 31, 2017 | Carrier Heating & Cooling
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
I have a dayton fuel trimmer furnace model # 3E438A and the problem is that upon ignition to the furnace the unit runs and after about 3 minutes the units inducer fan shuts off and the flames stays on....
It sounds to me like your draft motor is probably shuttimg off on thermal overload. They will get to hot and shut down until the motor cools down then run again.But by that time it's caused other trouble so I think you need to replace the motor first and then see what other problems it has caused.I hope this helps you and thanks.
Jan 10, 2011 | Heating & Cooling
I have a Amana Prestige II model number RCC42AZE, First I noticed the air was not cold then when I looked at the air unit outside the fan was not running. What can I do without spending a fortune to get...
does the blade spin freely with the unit off, if not the may be oil ports on the top and bottom edges of the motor. will it spin with the unit trying to run, if it feels like it is magnetized you need a motor.
Aug 05, 2009 | Heating & Cooling
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Dometic Rooftop RV Air Conditioner Logo
27 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
