Question about GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer
My GE washer WHSE5240D1WW stopped spinning. There is no agitation or spin cycle anymore. The spin cycle quit first then the agitation. At first when it was supposed to start the spin cycle I could grab the agitator and give it a good spin to get it to take off. Soon, everything quit. It doesn't even sound like it's trying. It just fills with water, sits there for a while and then drains it.
  • GE Master
  • 3,361 Answers
Remove the front panel and check for a broken belt.
Posted on Sep 16, 2010
  • elstasho Sep 17, 2010
    I looked into it and the belt is still there and still tight.
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Jul 02, 2009 | GE WBSR3140DW Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer Logo
698 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
