Question about Garden
I am looking for the Manual for my Stainless Steel Jamie Durie Patio (6 Burner) Hooded BBQ with side Wok burner and front cabinet, as I have lost mine.
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
SOURCE: Need to find lpg jets for 6 burner aussie roaster
BBQs Galore sell these in their DIY section (Aussie Roaster is no longer sold at BBQ Galore, but the burner component is a standard fit). If you have an Aussie Roaster remember there is a bobbypin on the underside of the burner locking the back end of the burner in place, a few smacks with a little hammer will push this out so the old burner can be pulled out and new burners can be put in place.
Posted on Jan 23, 2010
  • 10 Answers
SOURCE: How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Posted on Apr 11, 2010
  • 150 Answers
SOURCE: Pilot light on my Charmglow
The themal couple is probably the culprit. You will see one end of it hanging into the pilot. The pilot heats that end creating a small electric current that allows gas valve to operate. There is a small copper line from the tip near pilot other end goes into gas valve. You can buy universal replacement kits. Usually around $15.00. RV parts store good place to look.
Posted on Sep 29, 2010
TheMobilian
  • 8220 Answers
SOURCE: Outdoor gas grill from BBQ
The new propane tanks have a safety valve inside them that is real touchy. Remove the tank from the grill and open all the valves up then close them all back. Reinstall the tank and SLOWLY open it just a little bit. Then retry. More HERE
Posted on Jan 03, 2011
How much does the hss-a-ss stainless steel patio heater cost?
There are many generic patio heaters that use standard model codes, it can be very difficult to find who the supplier is. HSS or SS is a standard Chinese factory code, to find a price and supplier take a look locally or via the web and ask for Chinese patio heaters. Worth asking if they have a stainless steel burner, many just fit a chrome or tin plated burner, for more information found this very useful specialist patio heaters.
Jun 08, 2012 | Stainless Garden Sun Steel Propane Patio...
My 2 year old (rusted and looking like a 10 year old) Pilot goes on lights the heater, burns for about 2 minutes and goes out. I tried another regulator, same problem. Gas tank is full. The pilot light...
Heaters that have rusted are tin plated or chrome finish, it can be hard to get a stainless steel heaters since some traders sell heaters as stainless steel but don't tell you the burner is made of tin. If you get a new heater just ask the question, is the burner tin or stainless steel? The problem with a burner that goes out can be a simple as changing the thermocouple, these are consumable and last between 2 to 5 years depending on use and storage. But if you have a yellow tipping this is not good, this can be caused by wrong fuel mix or faulty gas valve and is not an easy fix. Found this site very useful patio heater problem solving. Lots of info.
Oct 23, 2011 | Coleman (5040B750) Patio Heater
I can light pilot but cant get main burner to stay on. Ive cleaned out hooded pilot with wire. what next
Clean the gas tube before the pilot light with a small wire. If you don't light these units every month or so you can get all sorts of bugs and critters that will call your gas tube home. Second option - Either the thermocouple is bad or the gas control valve is not opening completely. Try replacing the thermocouple
Mar 05, 2010 | Endless Summer (GA200209) Stainless Steel...
GC913 wok ignitor installation
The electrode goes through the wok burner bowl then the spring fits under the bowl. You have to push it up until it clips into the groove on the electrode. Should be quite a tight fit.
Mar 27, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Chain
It is used to maually light the burner with a match. The match goes in the "loop" part. It is attached so that it isn't lost/
May 12, 2007 | George Foreman GP324 Stainless Steel Grill
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
