Question about Singer 5050 Mechanical Sewing Machine
My bobbin winder on the 5050 model singer sewing machine does not seem to work. You can hear it running, but will not turn bobbin.
    Genius:
  • 1,788 Answers
You have a very nice machine, I looked up your manual on www.singerco.com for free, even if you have your manual it would not be a bad idea to download this one for backup. Now, do you have your machine threaded right for it to work? Take a look at the diagrams, I love the online one because you can make the diagrams larger and spot some of the errors easier. I have been sewing for 50+ years and amaze myself sometimes at the rookie mistakes I can make. I have 6 sewing machines and each one has their own quirks. Good luck and if you are stuck give Singer a call at 1-800-4singer and they can really help you out.
Posted on Sep 17, 2010
Just received a singer futura II model 920 which seems to sew just right. When I tried to wind a bobbin, I just can't get it done.
If it is a new machine, take it for warranty service. Sounds like perhaps something is misaligned with the release lever. In the meantime, a standalone bobbin winder can be purchased at JoAnn's, Hancocks, or Amazon.com for about $35 (helps reduce wear & tear on your machine).
It's very difficult to say whether it is worth the price of repair. On the other hand, what would you do with a machine that doesn't work? It could be something very simple that can be repaired for a small price, or it could be something expensive. (However, since you indicate it is only the bobbin winder that is faulty, otherwise the machine works with that one exception, you can save up to get the bobbin winder fixed.) FWIW, a standard check, clean & oil could cost around $100 (based on what I currently pay for my machines). However, you could ask what it would cost to fix the bobbin winder only.
From a search on eBay:
http://www.ebay.com/sch/i.html?_nkw=singer+futura+920
You can track similar machines and their sales prices to determine if it would be worth fixing your machine. Even if you don't, you can still purchase the standalone bobbin winder and continue to use the machine anyway. A working machine is better than none at all.
Feb 02, 2016 | Singer Sewing Machines
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
Singer 5050c when I move the bobbin shaft to engage to fill the bobbin it won't engae
That usually means the clutch or belt is worn out, and it's not worth fixing. You can buy an inexpensive bobbin winder for under $25.00 at WalMart online, and if you pick it up at a WalMart or FedEx facility like Kinkos, shipping is free. Does a better job anyway!
Jun 11, 2014 | Singer 5050 Mechanical Sewing Machine
My singer quantum 9940 bobbin will not fill even. What seems to be the problem?
There's a small screw on top of bobbin winder on your machine. Turn screw to adjust pressure where bobbin meets the winder when winder is pushed to right to wind it. Test with small turns until you are satisfied with appearance. Make sure nice, even fill- as you know, imbalanced bobbin will reak havoc. Jimmy
Apr 09, 2012 | Singer Sewing Machines
The bobbin winder on the top is not working. i can hear the motor going but it doesnt spin
Could be oil on the bobbin winder rubber inside. Make sure the bobbin is not rubbing anything.
Dec 12, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin winder "washer"
It's called the
"bobbin winder friction ring"
You can find one on the site below for $1.50 or so.
https://www.vintagesingersewing.com/catalog/index.php?cPath=42&osCsid=7697cebcf0714ac3da8b2c1101c98365
It's the last listing for machine parts.
Hope this helps, please rate this if helpful
thanks
moni
Sep 15, 2009 | Singer 5050 Mechanical Sewing Machine
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Singer 5050 Mechanical Sewing Machine Logo
97 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
