Question about Gateway FPD2275W LCD Monitor
How do I get the case apart after the screws are out.....Guessing I have caps bad or something
  • 979 Answers
Hello sir, hi, need to tweek the sides to loosen the snaps. follow this video to get the idea: http://www.youtube.com/watch?v=5WLzdjYnbDE
Posted on Sep 16, 2010
The screen on my Compaq nc6320 only shows the proper image when I grab the top of the screen with one hand (while holding the unit stable with the other hand) and twisting it counterclockwise against the...
An interesting problem you have there! It does seem like it's a bad connection somewhere, so yes. I would suggest that you take apart the screen portion of the laptop and take a look at the connections. It's not too difficult to do that. This guide will help you out: http://www.lcds4less.com/laptop-lcd-removal-instructions.shtml Hope this helps!
Apr 08, 2011 | Compaq Presario Notebook
There is a dust inside the screen how can i open acer x193 lcd?
Service manual:
http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=x193&kategoria=monitor&kat2=all
Use thin flat blade screw driver for separating the case.
Are you talking about the dust INSIDE the LCD panel? Taking apart LCD panel is VERY DELICATE WORKS, not reccommended.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 03, 2010 | Acer Computers & Internet
After couple hours of use the screan will go black and power led will flash. If left unpluged for a while (2-3) hrs and is pluged back in it will work again for a short piored of time. I was guessing that...
Just repaired mine. Had a couple of bad caps on the power board.
For disassembly, on the back the two hinge covers will slide off sideways, exposing 4 screws holding the hinge assembly to the monitor. remove that piece and you can get to all three screws holding the plastic monitor shell together. After those three screws are removed, its just snapped together so use a small screwdriver or blade to pry apart. I started at the button area on the bottom and worked up from there. Good Luck.
May 17, 2010 | Computers & Internet
Gateway (FPD1830) LCD Monitor
It can be bad caps in the power supply, bad inverter circuits (check the green color fuse (F1, 4A 125V) close to the heatsink and a trim pot), bad inverter transformers, bad lamps.
You open it up using flat blade screw driver starting along the bottom edge of the case. Post back what you see insdie so we can guide you further.
Feb 23, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
NEED TO CHECK FOR BAD CAPS IN VIEWSONIC vp2130
To disassemble your monitor follow these steps.
1. Remove the stand, usually 2 to 4 screws
2. Now there will be screws in each corner on the back of the monitor.
3. Take a small flat blade screw driver and seperate the two halves of the case. The front and back are held together by plastic latches spaced several inches apart around all four sides.
4. After the back case is off the boards you will be looking for are under the metal shield, remove the screws that hold it on.
5. Check my web site at www.ccl-la.com , we have pictures of what the bad caps look like if you are not sure.
6. Be sure to replace any capacitors that have raised and blown tops.
I hope this helps, If so please rate my solution.
If you need more info let me know.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Hp pavillion f1903
It has a bad capaitors in it open it up look for bulged capacitors replace all bad ones and it will run again i fixed more hps with this problem than any other and it doesn't cost much to fix its under $10.00 thank you have a nice day
Jan 12, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Types in upper case only (without caps lock/shift key locked)
in most cases yes, BUT since the light for caps lock is not comming on you might have a bad P.O.T. on the keyboard layer.. Since im assuming we are talking about a laptop..
Mar 07, 2008 | Acer NSK8458AN Keyboard
Screen blacking out.
Hi, I used to fix a monitor from Dell. There are 4 screws at the back of rear panel and no screw at front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
For the metal plate that shields the back of the screen, There are some screws you have to deal with. Those screws are at the power and screen connectors.
Thank you,
Tan
Mar 01, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
