Question about Refrigerators
I need a manual to operate commercial freezer ASECO LF817LD. Do you know where I can get one. We are a refrigeration repairs business and need the manual
3 Suggested Answers
  • 25 Answers
SOURCE: R-22 refrigeRATOR OPERATING PRESSURES
google refrigeration pressure temperature chart
Posted on Jan 24, 2010
  • 83 Answers
SOURCE: I cannot locate my owners manual for my Imperial
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Posted on Apr 22, 2011
Is it worth fixing a 30 yr old Traulsen commercial reach in refrigerator/freezer? The compressor on the freezer needs replacing but the refrigerator is working fine.
Is there a compressor for the refrigerator separate from the freezer? Weigh the cost of repairs against the cost of a new unit, then decide.
Mar 16, 2016 | Traulsen Refrigerators
Need repair manual to fix cap tube on coldtech j6srf61b refrigerator freezer
All you need is the same size cap tube, and coil it the same length as the one that is on there now.
if its typical refrigeration you will need to recover the charge and braise in the new cap tube. Then recharge the unit
Aug 23, 2013 | Coldtech J4SRR-40B Commercial Refrigerator
My freezer mod#ULG80BC-5 every morning the disply
I dont provide refrigerator repair service on commercial units, but my first instinct is to say that E7 is an error code message, likely pertaining to a self diagnostic system, but you would also likely need the manual to determine the source of that error.
Sep 27, 2010 | Carrier Commercial Freezer CFG48
Jan 22, 2010 | Traulsen Commercial 2 Door Cooler /...
Commercial walk in freezer door damaged needs repair or replace?
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Nov 14, 2009 | Freezers
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Commercial reach in freezer
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 19, 2008 | Piper Products Freezers
Not cooling
thanks for the question no not a job for you you need gages and knowledge of operating presures let a service tech do this thanks the appliance doc
Aug 08, 2008 | True T-49 Side by Side Refrigerator...
Refrigerators Logo
241 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
