Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
What is the fuel line routing for a poulan 2375 chain saw
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
SOURCE: 2375 poulan chain saw brake is shot,how do I fix it?
You Likely by this time have resolved this. Mine messed up one day and I found a spring inside it. This spring wraps around the counter weights and pulls them together at idle speed, allowing the chain to stop, without stopping the motor. As you throttle it up and the RPM increases the spring allows the weights to push outward , engaging the chain. I have used mine without it, but I'm sure that would not be a recommended procedure, as the chain is always engaged, even when idling.
Posted on Oct 26, 2008
dennisgladx
  • 52 Answers
SOURCE: chain saw
My name is Dennis and I'll try to be of assistance.
1) There is a primer line kit that is of smaller diameter and it goes from the primer bulb to the tank and terminates at the fuel pick-up assembly. There is also another smaller diameter line that goes from the primer bulb to the carburetor.
2) There is also a fuel line kit that is of larger line diameter that goes from the carburetor to the fuel tank.
That's a total of three lines Tank to bulb and bulb to carburetor two lines four places to connect. and tank to carburetor that is the third line and the remaining places to connect the second place at the tank and tha last at the carburetor.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
dontbother10
  • 2220 Answers
SOURCE: The chain is not moving on Poulan 4018 Wild Thing
I think you are saying the centrifugal clutch does not engage. It should not at idle. Did you rev it up a little and it still not engage? There is a clutch face on sprung weights that should expand and turn the clutch drum above idle. Please see the “Handle, Chassis & Bar Assembly” detail for clutch illustrations.
A 2375 has an outboard clutch (the chain is between the engine and clutch drum).
2375 Type 7 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
Use this as a guide to remove the clutch and inspect the parts:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
A 4018 has an inboard clutch (only the drive sprocket extends into the clutch cover). Do this first then use the outboard procedure to remove the remaining clutch pieces.
PP4018 Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/PP4018-Poulan-Pro-Gas-Saw-Type-2/75.PP4018-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
If these are not your saw it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
You can reply below with questions or if 1 miss understood your problem. HTH
Lou
Posted on Jan 18, 2010
dontbother10
  • 2220 Answers
SOURCE: I have a Polan Model 2375 Wild Thing Chain Saw.
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 20, 2010
Testimonial: "Thank you for your help. Your instructions were correct.I did have to reverse the connections on the carburetor. My chainsaw works fine now."
How long is the fuel line on a poulan 2375
I never really measured them as I usually install them from my bulk line packs but the fuel kit has one 25" length for the pickup line and the return kit doesn't specify length. Note the new primer bulbs uses a different size return line then the original line.
Most chainsaws lines are under 12" each.
Dec 23, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Routing fuel lenes from carb.to primer bulb to tank and back to the carb.?
moz-screenshot.gif/www.ereplacementparts.com/poulan-2375-type-gas-chainsaw-parts-c-16962_17147_17263.html this will give you a good break down. select diagram B and you will be looking at figures 6, 12 and 14
Aug 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
WHAT IS THE FUEL LINE ROUTING FOR A POULAN 2375LE. IS THERE A ROUTING CHART?
The fuel line from the tank with the filter on the end, goes to the main fuel inlet on the carb, the conection nearest to the alloy pump cover held with a single screw, the other conection on the carb goes to the shorter of the two conections on the back of the primer ( the suction side ), the shorter of the two conections on the back of the primer ( the pressure side ) has a hose back to the tank, just remember the primer pulls fuel from the carb, into the primer, and then back to tank.
May 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is gas line routing Gas line broken in tank
Like the following link:
Typical 2375 IPL (may not be your saw)
All Poulan saws:
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
All my fuel lines fell apart. I do not know where they go.
All Poulans are similar, I am forced to believe your saw is a "2375 Type MyBestGuess".
An example IPL for a Poulan "2375 Gas Chain Saw Type 7" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly: It is deceptive it appears the filtered line goes to the primer, it doe not! It connects to the carburetor input. Trace your existing lines and they will bear my fuel schematic out.
A typical fuel system and a couple of hints can be found here:
If your saw is not a Type 7, you can find the correct IPL here:
Poulan.com
Lou
Apr 04, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a new primer bulb Poulan WildThing 42cc CS
Item 18 on the "Engine Assembly" detail IPL here:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If this is not your saw you can fin d your here:
Poulan.com
HTH
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace the fuel lines
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan 2375 Gas Saw Type 7 IPL.
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
I have a Poulan 2375 chainsaw. The fuel lines became brittle and broke. I purchased new lines, but I need a diagram to see where the belong... there are two different size lines... but where the heck do...
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here:
Poulan.com
Typical fuel System:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
478 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
