Question about Sharp LC46SB54U 46 in. LCD TV
Remove base to wall mount - Sharp LC46SB54U 46 in. LCD TV
  • Sharp Master
  • 5,469 Answers
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Posted on Sep 16, 2010
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
SOURCE: How to Remove the Base
The 2 screws on each side directly above the stand legs need to be removed. You do not need to remove the big plastic back panel. Remember the TV is heavy, the screws are under pressure and when the screws are removed the TV will drop. I suggest 3 people, 1 to remove the screws and 2 to hold up each side during and after the screws are removed.
If you want to remove the speakers, just disconnect the wires at the TV source, & remove top 2 screws from the brackets on each side of the centerline. Lower the speakers & rotate the bottom forward & out the front.
Posted on Jan 06, 2008
SOURCE: Wall mounting Panasonic Viera 32" tv
Took me a while to find this. Remove the two lowest screw, holding on the plastic back, in the centre and it drops out.  -- Andrew
Posted on Apr 27, 2008
  • 187 Answers
There are 4 screws on the back of the TV just above the base stand, remove those screws and then you can slide down the stand and remove it.
Posted on May 27, 2009
SOURCE: how to remove base on samsung 2333hd
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
Posted on Jun 07, 2010
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
Feb 07, 2010 | Sony KDL-32S3000 32 in. LCD Television
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Nov 14, 2008 | Coby TF-TV2608 26 in. LCD Television
Akai Plasma PDP42Z5TA - removing base stand
The base removes with the support arms that rise the height of the tv. remove all the screws from the back of the support arms and the base will slide out with the arms. you will need the holes open to mount to the wall mount
Jun 16, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Sharp LC46SB54U 46 in. LCD TV Logo
1,518 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
