Toshiba 32DF46 32" TV Logo
John Trevino Posted on May 17, 2008
Toshiba 32df46 power on message "please wait"
I have a 2006 32df46 when I power on after being off several hours, a message appears "Please Wait, Thank You for your patience" Sometimes this message appears for only a second, other times message remains for several minuites. Whats Up? Thanks
  • K111 Jun 25, 2008
    I have a Toshiba 27DF46 (27"). Now powers on with "Please wait. Thank you for your patience." Will not do anything else! Screen will stay that way for hours. Remote control will not bring up a menu or anything. Can only turn on and off. Period!
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
952
Points
7
Unfortunately the digital board is usually the cause. Part Number 72783389. Vey expensive part!
  • notoberelase Dec 14, 2010
    would this explain that after moving the TV and keeping it in storage for a year then pluging it back in that it would work again but only for 1 more year?
Carlos Principe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2014
Carlos Principe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
786
Points
Have anyone got this problem fix? And whats the digital board??
Anonymous
Level 1:
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
786
Points
I have tha same problen please help
Please wait message on toshiba e studio 205
Hi Leonie.
Please allow me to try to help you.
The reason why you get the - please wait message on toshiba e studio 205, could be because the HDD has become corrupt. Another for this could be a fuser error.
You can find more answers to this issue -
https://www.manualslib.com/manual/1058435/Toshiba-E-Studio165.html?page=135
http://www.copytechnet.com/forums/toshiba/87173-toshiba-e-studio-452-showing-wait-during-copying.html
http://theoryreport.com/technology/toshiba/toshiba-e-studio/fix-the-f10-error-code-on-your-toshiba-e-studio-copier.html
Attached is a tutorial that might help you gain more insight into this issue.
Hope that helps.
Best wishes. Regards.
2answers
I turn my computer on and comes up with toshiba and AMD turion 64 symbol and option f2 of f12. I push f2 and please wait comes on however it's been like this for several hours. What can I try?
Shut it off and unplug it, remove the battery and wait 20 minutes. Then replace the battery, plug it in and start it up, let me know if this works.
Toshiba c 650 showing piease wait a moment and restart mechine
I have seen several of these older models get stuck in "warming up please wait" mode due to bad hard drive. I have also seen same message caused by the electrical with insufficient amps.
My LCD dynex tv will turn on but keeps flashing on and off saying please wait
The fact that Please Wait appears on the screen that the power board is fine. I would unplug the tv for 4 hours and plug it back in to see if the same thing happens. It does appear that you need to replace the main board,
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
1helpful
Problems during Recovery of Factory Default Software
Don't stop the presses during recovery
its too bad to stop
wati more than 3 or 5 hours
cuz it depends on your pc specs
Power on Message "please wait
Hello
First try to reset its pascode. You can do it by following method
If you forget your password, press RECALL
four times within five seconds while the TV is
in password entering mode. This allows you to
reset your password.
If you can't or the set don't allow to do this, call the authorised service personal, as the set is still booting, and does not compete it all. To retify this, you have to enter its service menu, and it is a very very skilled job, and you can't do it by yoursef. OK
6helpful
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
