Question about GPS
My Garmin/nuvi 265w has lost its voice - GPS
  • 1,514 Answers
First press the speaker symbol and check that the volume is not down fully or that the mute box is not ticked. If it is press the mute box to untick it or increase the volume. Otherwise follow the instructions below.
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Posted on Sep 17, 2010
I have a Garmin Nuvi 265w and it stopped saying street names. How can i get it to say street names again?
From your main menu, tap tools>settings>language. On this page under voice, select a voice and make sure it has the TTS next to the voice for speech. If you do not have any, you need to download garmin webupdater from http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run garmin webupdater and follow the onscreen prompts. When you get to the additional updates page, scroll down to find the voice and update the ones you would like on your unit. Once the update is complete unplug your unit and allow it to restart. Then go back to tools>settings>language and select your voice.
Sep 27, 2011 | Garmin Nuvi 265W GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Garmin Nuvi 265W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
Hi i have a garmin 265 only 4 weeks old. i have lost all side roads and the navigation is well out. says im on the road next to me. i keep loosing gps signal also. any solutions??????????
I can help you reset and fix your Garmin Nuvi 265W.
Losing gps signal and poor tracking are indications that the firmware / system software inside your GPS need updating.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Mar 21, 2010 | Garmin Nuvi 265W GPS Receiver
No basemap n garmin nuvi
I can help you reset and fix your Garmin Nuvi 265WT.
A message about not finding any maps is an indication that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
I hope that helps.
Tip
Download Nuvi 265 Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 265 Car GPS Receiver
Tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 265W GPS Receiver
Voice command in not working
If your Nuvi 265W is not operating properly after an update, I recommend backing up your favorites and then performing a hard reset. Full instructions are below:
I hope that helps.
New WebUpdater Software here.
Dec 14, 2009 | Garmin Nuvi 265W GPS Receiver
We have 3 nuvi265w that have no voice. Also one will not pair to any bluetooth device. They had voice in the beginning and now do not. I did the update downloads and that seems to be when we stated having...
I can help you reset and fix your Garmin Nuvi 265W. If your nuvis are not acting properly after a webupdate, try it again with the newest webupdate software (available below). After backup up your favorites, and performing the webupdate, try the hard reset AFTER the webupdate. This sequence has been known to help.
  2. Download and then run Garmin WebUpdater to replace its firmware / system software.
  3. Perform a Hard Reset.
I hope that helps.
Oct 04, 2009 | Garmin Nuvi 265W GPS Receiver
Voice activation capabilities locked and none functioning after driving for 2 hours or so. Satellite reception getting lost even on a sunny day
Erratic behavior and improved satellite reception has been addressed in new system software / firmware update.
I hope that helps.
Sep 22, 2009 | Garmin Nuvi 265W GPS Receiver
GPS Logo
253 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
