Question about Star Logic 17" LCD Monitor
I have a 19" StarLogic FTf LCD monitor that comes on for a second and the goesw blank.
  • 732 Answers
Wallybanq, All Cold cathode fluorescent lamp back-lit monitors use same basic design and principle of operation!!! Your unit no different. Do you know how to evaluate monitor internal power supply status with aid of bright flashlight?? You will porbably need to investigate and repair the "switch-mode-power-supply" internal to the unit. Read fixya profiles of "budmrtn" "buddymc" "12fixlouie" for DIY repair info. Some "black screen of death" units can be repaired for less than $8 if you have or can borrow a 40 watt soldering pencil and some solder. Also check out the video clips at YOUTUBE. Also check out this site: www.badcaps.net Once you know what it is that makes the FIXYA web page "white", then you will know just how similar those new "curlieQ energy efficient, CFL light bulbs work. Good luck with the repair. 12fixlouie
Posted on Sep 17, 2010
I have a StarLogic 19" FTF LCD monitor that comes on for a second and then the picture go off.
Look for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 16, 2010 | Star Logic 17" LCD Monitor
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Red screen?
If the vga cable nicely connected may be the logic card in the LCD.
Jan 06, 2008 | Star Logic 17" LCD Monitor
BLANK MONITOR
the signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Dec 06, 2007 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Push button power broke Starlogic LCD 19"
My monitor Display show to wide.
Starlogic 19'
Nov 07, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
110 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
