Question about Samsung RS2630AWW Side by Side Refrigerator
NEITHER THE FRIDGE OR THE FREEZER ARE DEFROSTING PROPERLY. I HAVE MANUALLY DEFROSTED BOTH SIDES TWO DIFFERENT TIMES THIS YEAR SO FAR, NEITHER SIDE HAS FROZEN SOLID AT THE SAME TIME AS THE OTHER
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
My refrigerator is not cooling at the top on both sides both sides on the bottom is cold. its not blowing cool air from the freezer to the fridge and everything on the top is defrosted and has got to room...
Sounds like you have a frost blocked evaporator. That the term for a refrigerator which is not automatically defrosting. Unload the freezer, remove the shelves and the back wall out of the freezer, melt the frost with a hair dryer, replace the defrost heater at the bottom of the cooling coils and replace the white 1.5 inch long sensor at the top of the cooling coils.
Nov 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Tip
Defrosting Tips for Your Fridge & Freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Defrosting fridge/freezers is much easier with a two-control model. That way, you can use the fridge to keep foodstuffs frozen while you deal with the freezer.
Are you thinking of defrosting method for your freezer or fridge? Then check this out.
Always switch off and unplug the freezer before cleaning or defrosting.
Load the contents of your freezer into large dustbin bags and cover the bags with a duvet or blanket. The food should stay frozen for several hours. But use a cool box for ice cream or soup which melts quickly.
After defrosting, wash fridges and freezers with a solution of two teaspoons of bicarbonate of soda to 1 liter (2 pints) of warm water-it removes lingering smells.
Rub the inside of your freezer with glycerine, available from chemists, after it has defrosted. When you next have to defrost it, the ice will come away from the sides more easily.
Use a wet/dry vacuum cleaner to **** up any water left on the floor.
If you do not like defrosting, you can always pay more for a frost-free freezer which never needs it. www.victorwod1234.blogspot.com
on Apr 05, 2010 | Refrigerators
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Icing up, not defrosting corretly in freezer. Frig not staying cold enough.
Your refrigerator problem is directly related to your icing up - excess frost / icing up, defrosting problems causes cooling problems.
To rule out other problems shut down your unit and MANUALLy defrost it using a blowdryer, get all that ice buildup melted as well as the evap coils in your freezer - once it is fully defrosted put back the panel and turn on - give it a couple of hours to cool - if it cools properly, it is a defrost problem. Hopefully too, this resets your controlboard.
If problem returns eventually, you have a defrost timer problem and will need to get it checked - it can be any of the defrost components, controlboard, defrost thermostat, etc.
Sep 18, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Nov 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost Problem
the first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Sep 12, 2008 | Maytag MZD2766GES Side by Side...
Refrigerator is not cooling, but freezer is working properly
Usually it's because it's not defrosting. If there is frost buildup on the back wall of the freezer, it's a defrost issue. Most of the time these fridge have a defrost issue, it's because the defrost heater is bad. If this is the case you can get by for a while by manually defrosting the fridge. Take everything out, turn it off, leave the freezer door open and let it sit for 24-36 hours.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Fix it fridge
the compressor does not properly run ,motor valve weak ,test w/ amphere meter if does not match w/label amphere , comp. motor problem.
Dec 31, 2007 | Jenn-Air JCD2389G Side by Side...
Samsung RS2630AWW Side by Side Refrigerator Logo
54 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
