Question about Garden
Looking for a manual for a Philmore OHMS meter model# pnh301d.
  • 1,040 Answers
Try gong to this link and if you find your particular tool, answer one of the survey questions and you will get a free PDF download of your manual.
http://www.manualsonline.com/
Jim
Posted on Sep 17, 2010
I need instructions and codes for a Philmore PM-RC26 iniversal remote.
Check the slot in TV where the HDMI cable is inserted. On your TV remote control (not Philmore) there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. Now take the other remote control i.e. Philmore Universal remote in your hand. Press & release the S (set) button. Immediately enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
Check the Visio TV manual for the Brand name, Model no & TV code if any. Then contact your TV manufacturer or retailer for the TV code to enter & synchronize with your new Philmore Remote Control.
Nov 13, 2016 | Televison & Video
Frigidaire Refridgerator keeps going through the defrost cycle
the defrost cycle should come on about every 8-12 hours. You may have a defrost timer issue? I suggest testing it and the heating element with a multi meter.
Ur timer may be activating to fast for each cycle
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small ***** driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
God is so good: so this is why I give free advice so please thank him not me.
Mar 29, 2016 | Frigidaire Refrigerators
Food in fridge is freezing...vacuumed condenser ....still happening.....looking for suggestions on problem or troubleshooting
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
May 15, 2015 | Refrigerators
Freezer section is making a fan noise. Model RS261MDWP
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Feb 21, 2015 | Refrigerators
Reset the defrost timer
Dec 17, 2014 | Kenmore Refrigerators
How to manually initiate defrost cycle on kenmore #253.97360
Oct 03, 2014 | Kenmore Refrigerators
Fun one here.....Frigidaire model FRT21IL6B2---- Ice maker stopped, freezer & fridge are NOT cold enough. Freezer coils keep freezing over. Fans are both working. Lower coils have been cleaned. Co
Sep 29, 2014 | Dryers
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Universal remote
Try these magnavox codes 011, 012, 013, 003, 043, 047 they are for a Philmore Commander remote
If your remote has 4 digit codes add a zero to those or try these.
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
May 02, 2008 | Televison & Video
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
