Question about InFocus SOFTCASE, LP425Z Multimedia Projector
INFOCUS LP 425 DLP PROJECTOR PROJECTOR POWERS ON AND THE INFOCUS SCREEN FLASHES BUT THE COMPUTER IMAGES WON'T SHOW. iT JUST READS PERFECTING IMAGE BUT NOTHING EVER HAPPENS
  • LRAY32 May 17, 2008
    the lamp is comming on and I have checke the lens. One other thing when I went to the menu to adjust the image or It would not let me adjust the color as a matter of fact there was nothing showing(no color) the bar was blank.
    Brigadier General:
  • 3,614 Answers
Try to restart the pojector & the pc, &
check the connection of the projector, some projector needs to warm up before it goes to work..
Posted on May 17, 2008
  • micromaster
    micromaster May 17, 2008
    did you use a laptop -or- pc to connect the projector.?
    Some laptop actually did not turn the external video display, such as projector.. There was an Activation command which needed
    -or-
    On some
    laptops, the activation function key is labeled with an icon, for example or the text CRT/LCD (fig. 1-A)
    FIG. 1-A
  • 3,037 Answers
This symptom suggests that the projector is out of range of the computer. How do you have the devices connected exactly?
  • 19,396 Answers
Check the lens and also check that the lamp is coming on
  • 1 more comment
  • Ginko
    Ginko May 17, 2008
    Turn off projector and computer and start them back with connection on, starting from laptop, check that the projector input is set up for the current connection to computer. Ensure also that the connection cable is ok. If this does not work then probably there is a fault, in this case refer to post above.
  • Ginko
    Ginko May 17, 2008
    It does not let you adjust the color because it does not detect the connection, check cables and input settings.
  • Ginko
    Ginko May 17, 2008
    Additionally some laptop have a function key combination that switches between output to built-in LCD, output to external monitor , and output to both built-in and external simultaneously. In this case ensure the laptop is set to output to both built-in and external simultaneously, or output to external. After doing this restart the projector.
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
InFocus Projector-Searching
most likely it is your cable. If a for sure brand new cable doesn't fix it it is most likely the main board. Also try flashing the software again.
Apr 28, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
PC expands and shrinks text/images when connected to projector
the resolution doesn't match. go into the menu on the projector and select auto image. this should clear up the resolution prob.
Jun 24, 2009 | InFocus LP 425 Multimedia Projector
DLP Infocus Problem
first of all, the infocus lp 790 is an lcd projector, not a dlp. second, the light filter in front of one of the lcd panels is burnt, and unfortunately cannot be purchased separately.
May 11, 2009 | ASK Proxima InFocus LP790 and Proxima...
Infocus lp640 lcd projector
check vga cable(cable between computer and projector)-try fn key with combination of f4orf5 orf6 or f7 or f8-confirm that input source assigned to pc.
Jul 08, 2008 | InFocus Office Equipment & Supplies
286 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
