Question about Plantronics CS351N SupraPlus Wireless Headset
My plantronics bluetooth plantronics 2200 is enabled on my blackberry, but it is not working.
4 Suggested Answers
  • 3 Answers
SOURCE: pairing my bluetoth to my blackberry curve phone
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
Posted on Aug 28, 2008
SOURCE: how do i pair my plantronics explorer 222
i looked up the users manual online
Posted on Mar 23, 2009
Diamond E
  • 57 Answers
SOURCE: plantronics explorer 233 bluetooth and blackberry 8100
On your main screen scroll down to the bluetooth icon.
click it
add device will appear
click "search for devices from here"
then get your bluetooth
hold the side button until it flashes red and blue. then release
it will find your bluetooth
scroll up and highlight it.
the passkey is "0000" when it ask for it
then click again
let the 2 pair
you should be golden
Posted on Apr 26, 2009
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can you play music through a plantronics 220 from a Blackberry 9700?
Yes! I have the same phone and headset :) When your in the song (and your bluetooth is connected, press the BlackBerry button, and select, "enable headset".
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 | Cell Phones
Plantronics explorer 233 bluetooth and blackberry 8100
click it
then click again
let the 2 pair
Mar 12, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Good luck from Headsets Direct!
Sep 22, 2008 | Plantronics Explorer 330 Headset
Connecting bluetooth to blackberry
Hi. You didn't say which Blackberry you have. I'll assume you know who to open "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your Blackberry.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your Blackberry.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Hope that helps!
May 25, 2008 | Plantronics Bluetooth Headset 610 Wireless...
Plantronics CS351N SupraPlus Wireless Headset Logo
448 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
