hi..i do not know if this is the reason for my probem i am getting with capturing DV just trying to narrow it down i cannot seem to check that my drive is using dma as in the "system properties" for the drive is blank and every time i check it its removed on reboot,but the bios reports on boot up "AWARD" thats it is LBA 46GB UDMA
i was just wondering if this is the cause of not giving me the performance on capturing dv souce clips without dropped frames is there a utilities to check this the bios is set to udma /auto
Pentium 3 256 133mb 9 gb scsi uw (boot disk) 46gb ibm desktar ata100 slot ide1 riva tnt2 pro 32mb
i tried the ibmtools and it made no diffrence to use ata66 or ata100 but i removed the 2 cd drives and the speed access has double to 4001.0kps still to slow any other suggestions as i am now desperately going in circles
thanks
Was this helpful?
Yes
No
Solution #2
posted on Aug 11, 2005
Rogers - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You didn't post what OS you're running under, which would be extremely helpful - but i'll assume you're running under Win98/ME based on your "checkbox" question.
There exists an issue with the Win9x core and UDMA. If the maximum UDMA speed of the drive is different (greater) than what Win9x thinks is the maximum speed of the IDE controller, it will automatically disable UDMA just like you posted.
Try setting the drive up for UDMA/66 (if you don't have the utility grab it at http://service.boulder.ibm.com /storage/hddtech/ibmftool-inst all.exe) and retest it. With a deskstar 46mb you should probably be doing at least 30mb/sec sustained transfer rate in disk inspection test.
Was this helpful?
Yes
No
Solution #3
Rachel007 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
if this fails which windows does work if nany with udma
thanks again fogg
Was this helpful?
Yes
No
Solution #4
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On Sun, 25 Feb 2001 01:13:11 -0000, fogg Seems awfully low. A 46 Gb IBM ide disk drive should do in excess of 25 Mb/s at least during burst. I suspect you have a driver problem. Then again, that can be said for almost all windows trouble :-)
Good luck, Jurriaan
-- BOFH excuse #138:
BNC (brain not (user brain not connected) GNU/Linux 2.4.2-ac3 SMP/ReiserFS 2x1756 bogomips load av: 0.35 0.08 0.02
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
thanks... but anyone point me in the directon has it driving me nuts ;-( should the highpoint driver be installed even though i am not using raid as i am only using the drive on ide 1 master as every time i install this under scsi properties on reboot it crashes "blue screen" if i dissable them it boots up but does not cure my slow speed on the ata drive please any suggestions thanks your may be right on one thing at the mo "user brain not connected"
Was this helpful?
Yes
No
Solution #6
Powe33 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Does this seem right?
Random access time 9.5ms Read burst speed 2mbps
Read speed- maximum 2033.0kps Minimum 1538.okps average 2003.0kps
I cannot see my farm on farmville and the following error appears:farmville 8862 handler already...
(More)
I cannot see my farm on farmville and the following error appears:farmville 8862 handler already exists. What can I do?
my eMule program tells me "it cannot reach TCP Port 11522, review your network...
(More)
my eMule program tells me "it cannot reach TCP Port 11522, review your network configuration". I use Norton System Works 2007 Premium and a new Thomson broadband modem/router. It worked fine before tv company installed the new broadband modem/router. Windows XP firewall is off. Can you help me please?
Will not insert multiple addresses into TO of an email. --> If I choose ONE selection from...
(More)
Will not insert multiple addresses into TO of an email. --> If I choose ONE selection from the ADDRESS BOOK, it moves to the e-mail. If I choose MORE THAN ONE selection, NONE move to the email. Several months ago everything was fine--now won't work. Thanks...
