Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Humming sound in the refrigertor motor - GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
My dishwasher starts humming in middle of cycle and wont go further the rinse cycle works fine
Hello & Welcome to FixYa
Either of these two things can cause this problem: first is the timer motor, if the sound is coming from the control then the timer needs replacement. If the humming comes from the bottom of the unit then it is the motor that needs replacement. When the motor won't work you usually hear humming sound and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 14, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwasher fills with water then hums
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
MY DRIER JUST STARTED MAKING A LOUD HUMMING SOUND WHAT DOES THAT MEAN?????
You must see if this is the hum of the motor or that of a mechanical friction of the motor assembly. If the motor is humming please check the capacitor that is connected to the motor, change with the value specified on the capacitor.
If there is hum on the drive use good lubrication remove and reset.use degreasing spray to ease off friction
Sep 24, 2010 | Kitchen Ranges
Makes a humming sound in the back, and code comes up LE at start of the wash
if the motor is humming there is a fault with the motor,,it could be its just jamed up,,,however if its humming its going to get very hot,,,that wont do it any good at all, check the motor brushes first also check its not a capasitor type motor,,,if the cap has gone that will cause a hum in a motor as well
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Hoover SteamVac Dual V Carpet Cleaner just hums when I turn it on
if the motor doesn't run sounds like you either have a bad motor or your motor armature might have gotten wet and created a dead spot.if you have any contact cleaner spray a little on the armature then turn the motor by hand make sure its uuplugged first if you can turn the motor then plug it in and try to start it
Apr 04, 2009 | Vacuums
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
