Question about LG Refrigerators
The freezer seems to be working fine, but the fridge won't get cold I have it set at the highest (7) and still it's not cold
  • LG Master
  • 5,568 Answers
Posted on Sep 16, 2010
  • Steve Allison
    Steve Allison Sep 16, 2010
    Since FixYa managed once again to lose the message I posted, here it is again:
    Check in the inside rear of the refrigerator cabinet for vents. When you hear the compressor running, wet your fingers and hold them in front of the vent to check for air flow.
    If it seems there is none, then the fan that is supposed to distribute the cold air from the freezer is no longer running.
    If this is true, go to the Sears parts department and enter make and model number to see if they have a line drawing illustration of your unit.
    This will allow you to see if this fan is accessible enough for you to DIY or if you need a pro.
    Sears parts department (http://www.searspartsdirect.com/partsdir... )
    Good luck-
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
My freezer wasn't defrosting and the fridge wasn't as cold as it should be. I emptied it out and unplugged the fridge for 2 days and plugged it back in. Settings for freezer and fridge are on the highest...
hi how are you...please turn down setting to original setting from factory...in the freezer,does the back panel have ice on it....if so you have defrost problm...if not remove panel...if one one place on coil has ice ,but not whole coil...then has a freon problm....allow 24 hours for settings to readjust....hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...call if need assistance...good luck...
Mar 26, 2010 | Maytag MTB1956G Top Freezer Refrigerator
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
62 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
