The screws that hold the lid switch loosened all the way, and will not tighten back up. How do I open the machine to secure the lid switch? Thank You - Km
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description, "the screws that hold the lid switch loosened all the way, and will not tighten back up"
it sounds like you`ll need to replace the lid switch, but first...
( this is also based on the idea its a whirlpool made top load, but you haven`t specified )
This is a common problem with these type of units since the assembly is made of plastic, fortunately changing it is pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 16, 2010
Fills with water then does nothing. won't agitate or spin. I checked coupler and it is fine.
The problem is with the lid switch. Disconnect both hot and cold water line from the water inlet valve. Mark the hot and cold so you don't get them mixed up. There are 2 philips head screws at the back of the machine, holding down the console to the cabinet. One in each rear corner. Slide the console forward slightly and tilt back. There are 2 metal clips that hold the cabinet and top to the back panel. Use a screwdriver and pry both clips up. ( pay attention on how to put the clips back). Disconnect the harness to the lid switch. Now stand in front of the cabinet and tilt forward towards you while pulling forward. Cabinet should slide forward. Once the cabinet has been separated fro the back panel, lift the lid up. On the right side of the lid you will see 2 screws. remove screws. (theses are the screws that secure the lid switch to the top). Now go to the back of the cabinet at the opening and look in the corner where you just removed the 2 screws, You will see a green ground wire screwed to the cabinet. Should be a 5/16 screw. (not 100% sure). Remove screw. there are 2 small clips holding the tubing for the wire harness in place. Popping both clips out should release the lid switch. Now disconnect harness holder from the top of the cabinet by pressing in the plastic clips at the side. Pay attention to the direction of the plug. Put the new plug in the same direction as the one you removed. Once you have inserted the plug and it snaps back into place, thread the tubing back behind both metal clips and clip those back in place. Secure the ground wire back to the cabinet. Now mount the lid switch back to the cabinet. You can do this with the lid up. Secure both screws into the lid switch. Close and open the lid to test the lid switch. You should hear a clicking sound. Now its time to put the cabinet back on.
Standing in front of the cabinet, tilt it forward towards you and line it up with the base frame. Tuck the front bottom lip on the cabinet under the lip of the base. Make sure that the tabs sticking up from the base lines up with the bottom of the cabinet. Be patient, may take you awhile to get the cabinet back in position.
Slide the back panel forward back in place. make sure it tucks into the back of the cabinet. Once its in place, now you can reinstall the two metal clips that secure the back panel to the cabinet. reconnect the harness to the lid switch. Tilt the console back down into place inserting the tabs on the side into place on the cabinet. Once in place slide the console backwards into place. You can now put the 2 screws back that hold the console to the cabinet.
That should do it. Plug the washer back in and start using.
Feb 14, 2011 | Roper RAS6233KQ Top Load Washer
Tip
How to Change Lid Switch on Roper RAS6233KQ Top Load Washer
<span>Disconnect both hot and cold water line from the water inlet valve. Mark the hot and cold so you don't get them mixed up. There are 2 philips head screws at the back of the machine, holding down the console to the cabinet. One in each rear corner. Slide the console forward slightly and tilt back. There are 2 metal clips that hold the cabinet and top to the back panel. Use a screwdriver and pry both clips up. ( pay attention on how to put the clips back). Disconnect the harness to the lid switch. Now stand in front of the cabinet and tilt forward towards you while pulling forward. Cabinet should slide forward. Once the cabinet has been separated fro the back panel, lift the lid up. On the right side of the lid you will see 2 screws. remove screws. (theses are the screws that secure the lid switch to the top). Now go to the back of the cabinet at the opening and look in the corner where you just removed the 2 screws, You will see a green ground wire screwed to the cabinet. Should be a 5/16 screw. (not 100% sure). Remove screw. there are 2 small clips holding the tubing for the wire harness in place. Popping both clips out should release the lid switch. Now disconnect harness holder from the top of the cabinet by pressing in the plastic clips at the side. Pay attention to the direction of the plug. Put the new plug in the same direction as the one you removed. Once you have inserted the plug and it snaps back into place, thread the tubing back behind both metal clips and clip those back in place. Secure the ground wire back to the cabinet. Now mount the lid switch back to the cabinet. You can do this with the lid up. Secure both screws into the lid switch. Close and open the lid to test the lid switch. You should hear a clicking sound. Now its time to put the cabinet back on. <br />Standing in front of the cabinet, tilt it forward towards you and line it up with the base frame. Tuck the front bottom lip on the cabinet under the lip of the base. Make sure that the tabs sticking up from the base lines up with the bottom of the cabinet. Be patient, may take you awhile to get the cabinet back in position. <br />Slide the back panel forward back in place. make sure it tucks into the back of the cabinet. Once its in place, now you can reinstall the two metal clips that secure the back panel to the cabinet. reconnect the harness to the lid switch. Tilt the console back down into place inserting the tabs on the side into place on the cabinet. Once in place slide the console backwards into place. You can now put the 2 screws back that hold the console to the cabinet. <br />That should do it. Plug the washer back in and start using.</span>
on Mar 18, 2011 | Roper RAS6233KQ Top Load Washer
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
My top loader whirlpool washing machine (model SM8280869, I think) will not drain or spin. I have checked the inlet and drain hoses, they are not clogged or kinked, and the drain hose is about 12? above...
The switch needs to be secure and make sure that the wiring did not come off the back of the switch. On the back of the washer there should be two or three screws holding on metal brackets that keep the top and the rest of the washer together at the seam. Once removed you should be able to lift the top up and out enough to inspect, keep in mind that the rest of the wiring for the dials will be still connected. Hope this helps and dont forget to unplug first
Jan 18, 2011 | Washing Machines
I have a Whirlpool Gold Ultimate Care II washer (MOD# GSQ9669LW0) The washer stopped, was full of water and will not restart on any cycle or settings.
This problem sounds like a broken lid switch. Power to the drive motor is routed to the lid switch and if the lid switch fails, the machine will fail work on any cycle. Verify this by bypassing the lid switch.
Disconnect power to the washer then remove the screws securing the console to the rear of the cabinet.
Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
Jump a wire between the outer terminals of the disconnected connector from the top of the cabinet then reconnect power. The problem is indeed the lid switch if the machine starts. Check the lid switch plunger and the lid switch attachment to the cabinet. It may not activate properly if the mounting is loose, re-tighten it. Replace the lid switch if the plunger is intact and and if it is mounted tightly and properly.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 11, 2011 | Whirlpool Washing Machines
Model # 110 20702 990 S/N CK 2841239 Type 111 Machine fills and drains,but will not spin.Is this washer a direct drive? Noise when trying to spin,sounds like gears are sliding by each other. Thank...
This is a direct drive washing machine and if it fills and drains but doesn't agitate and spin, the problem is a broken motor coupler as indicated by the gear-like sound sliding by each other which means the motor is running. The machine drains because the drain pump is directly coupled with the rear spline of the motor. Replacing the motor coupler should solve the problem.
Disconnect power then release the console from the top of the cabinet. Pull or pry off the end caps then remove the screw that secures the console to the cabinet top. Once the screws are removed, pull forward and up on the console and lay it back on the hinges.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and remove the clip. Hold the motor from the bottom while loosening the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
Remove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even with the edge of the coupler.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Jan 08, 2011 | Kenmore Washing Machines
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite, with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
When the seat is closed there should be two plastic extensions about one and half inches long, lying flush on the base. Open these with a small screwdriver, like a ****-shell. There should be a regular head screw there and correspondingly underneath the screw, a nylon nut. hold the nut and tighten the screw.
Please rate this answer for me. Thank you
Mar 21, 2010 | Home
The switch in the lid is so loose the tab will not operate it... How do I take it apart to tighten?
Open the lid, the screws that hold it are in the lip of the washer. 2 phillips screws. You should be able to hold the switch and tighten the screws without removing tha cabinet. I found a marvelous video that shows how to replace the switch HERE
Jan 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher cycle once then quits
You may have faulty pump or control board, If it was control board, then washer probably wouldn't work at all, so it is a last solution, The pump however may be faulty if you are not getting water, water is slow or your machine is not draining, or your machine won't run.
A faulty door switch can also cause you some problems:
Servicing the Lid Switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailed here. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Servicing the Water Pump
To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be food in the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Step 7: Reconnect the hoses leading to the pump.
Aug 25, 2009 | Ariston Technologies LI640S Dishwasher
Washing machine tub is not spinning and holding water
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
If you have a hidden lid switch (no visible hole around the top where the lid closes) try tightening the screws on the lid hinges.
Jun 18, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
