Question about Whirlpool Duet GHW9150P Front Load Washer
Last night's load ended excessively wet. Ran Rinse and Spin again, all good. Then about 1 hour later noticed water in tub. By today, water up and over the front running out on the floor. Ran Drain and Spin, but water returned.
  • elithepc Sep 17, 2010
    Thanks Fridgetech! Since I posted, we found someone on FixYa with the same problem last year! We'll check out our valves. Until then, water off to washer!! Thank goodness I was home when it decided to fill up!
  • 473 Answers
If water is coming in while the machine is off then the water valve is bad.
Posted on Sep 17, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
The spin cycle does not get the clothes dry enough for the dryer. I have to rerun the spin cycle after every normal wash, rinse and spin.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 16, 2010 | Washing Machines
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Maytag washer will not cycle.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 08, 2009 | Maytag HAV2557 Top Load Washer
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Keeps on rinsing and spinning over and over again
Aha! Mine was doing the same thing and I also noticed that there was some excess water in bottom of the tub - not the tub that the clothes go in but the one that that tub is sitting in. Does that make sense? Anyway, I cut the zip tie that holds the drainage hose, brought the hose as close to the house as possible and siphoned the excess water out of the tub. After this I tried a small test load and it worked no problem. I think the fact that there was this excess water left in the machine made the load too heavy to start the spin cycle.
Hope this helps.
May 28, 2008 | Haier HLP21E Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
