Question about Epson Artisan 800 All-In-One InkJet Printer
On power-up I get a Scanner Error requesting that I power-down and back up. The message is as follows: "A scanner error has occurred. Turn off the power, wait a few seconds, then turn on again. " All the soft keys are flashing and the suggested solution does not fix the problem.
SOURCE: scanner error
Try flicking the transportation lock (on the left side under the scan lid) on and off. It has a picture of a pad lock shown locked and unlocked. Flip it back and forth and leave it in the unlocked position.
This worked for me. Good luck!
Posted on Oct 17, 2007
SOURCE: the red light is on and the message scanner error.
Inky
  • 691 Answers
SOURCE: Service Req C0302
CPU Error. Mainboard is faulty.
Posted on Jul 23, 2008
  • 110 Answers
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the front of the scanner.
4) Turn on the printer, and the error should be cleared.
Posted on Aug 22, 2008
  • 15 Answers
SOURCE: Scanner is making a weird noise when printer gets switched on....
Have you looked at the paper to see if there is any stuck in the printer, other than that go and do the same thing as changing your Ink cartages but don't move any of them and set it up again and see if that works.
Rgs
The StickMan
Posted on Jan 30, 2009
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
HP 7410 All-in-One Printer A 'Scanner Failure' message is desplayed on the printer's front panel
I know i'm not going to get 4 thumbs up for providing this resolution because it seems like a hardware problem but what the heck you need some sort of help so here goes.
This error usually occurs when trying to scan or make copies. The scanner bulb is not hot enough or the electrical conditions are not suitable for the HP All-In-One product. Follow the instructions listed below to resolve this failure. The scanner lamp lighting should be viewable under the scanner glass right or left corner.
  1. c00439542.jpg 1 - Scanner lamp lighting 2 - Scanner glass If the scanner bulb does not light up, the HP All-In-One product may be defective.
  2. Make sure that the room temperature is suitable for the HP All-in-One product. Perform a Power Cycle on the unit by following the steps below:
    1. Turn the unit off.
    2. Unplug the power cord from the unit.
    3. Wait 30 seconds, and then re-connect the power cord to the unit.
    4. Turn the unit on.
    Check the power connections:
    1. Make sure that the unit is connected directly to the wall outlet and not to a power strip.Try a different wall socket.
    2. Every PC provides a standard power cord; it is possible to use it to check whether the electrical failure is prompted by the cord or not.
  3. If the Warming up or Scanner failure error messages persist, please move the unit to a different room or building to verify that the building (or room) is grounded properly.
  4. If your HP All-in-One product uses a external power module, check the power module part number against the part number listed in the User Guide to ensure the proper power module is being used. If both part numbers do not match and your product is still under warranty, please click the Contact HP link at the top of the page. If your product is out of warranty, please click the How to Buy link at the top of the page. c00458738.jpg
  5. Perform a Partial Reset by following the steps below:
    • Unplug the power cord from the HP All-in-One product.Press and hold the appropriate button combination for your HP All-in-One product. The appropriate combination for your model can be consulted in the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-in-One unit displays the Partial Reset message.
    Make a test copy of any document.If this copy is successful, the scanner mechanism is functioning correctly.If the error appears again, Follow the below troubleshooting
Noisy scanner This failure can occur when the HP All-in-One product is initializing.Every time the unit is turned on, the scanner carriage should move. Sometimes, when the scanner carriage returns to its home position, the carriage could crash and make a loud noise.Within a few seconds, the unit gets blocked, and the front panel display shows a Scanner failure message.Scanner noise could also be caused by the scanner sensor inside the HP All-in-One product being damaged or not properly in place.To solve this failure, follow the steps below:
  1. Perform a Power Cycle on the unit by following the steps below:
    Make a test copy of any document by pressing the Start Copy (black or color) button.
    • If this copy is successful, the scanner mechanism is functioning correctlyIf the failure remains unsolved, skip to the following step.
  2. Perform a Partial Reset on the unit by performing the following steps:
    • Unplug the power cord from the HP All-in-One unit.Press and hold the appropriate button combination for your HP All-In-One product. To know the proper combination for your model, check the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-In-One unit displays the Partial Reset message.
    Make a test copy of any document by pressing the Start Copy (black or color) button.If this copy is successful, the scanner mechanism is functioning correctly.
  3. Now if this still doesn't resolve the issue then it's a definite hardware problem my request would be regardless of the thumbs up,call up hp at 1800-474-6836 and ask for their upgrade machines because u'll get a machine with a 50-60% discount and an extended warranty with a 70-80% discount or u may get a warranty for the next two years for $1....Sorry if I can't help you
Oct 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
743 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
