Question about RCA TruFlat 27F520T 27" TV
When I try to turn my RCA PURFlat 27" TV on, either with the remote or main button a blue line shows up in the screen and like within 2 seconds it goes off. What's the solution for this problem)?
My rca purflat doesn't turn on with the remote, batteries are good, it however turns on when I press the power button and then the channel button.
Posted on Dec 21, 2010
Blue screen rca tv model 14f512t
you will have to take it in to get repaired. might of put a speaker or something megnatic near your tv.
Oct 21, 2012 | RCA 14F512T 14" TV
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27" home theatre, parantal controls
You need a remote a $7 GE universal will work good.
Resetting Your Password
Press VOL+
on the remote and the
CHANNEL + on the front of the TV at
the same time. Enter New Pwd.
will
appear on the screen. (You must be in the
Enter Password screen when attempting
this.)
Press the number buttons to enter a
four-digit code.
The code will appear on
the screen as you enter it.
Press OK to save the code.
to exit the
control.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
Problem with rca truflat 27f520t 27"
as you are seeing blue colour along with lines called retrace lines. solution 1 check supply to blue video circuit.& transistor. 2 check crt base for loose 3 check components in blue video circuit. 4 check for loose contact in connector. 5 check for signal processor called chroma ic.
Oct 01, 2007 | RCA TruFlat 27F520T 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA TruFlat  27F520T 27" TV Logo
126 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
