Question about Bunn SINGLE, includes One 1 Gallon Server
How can i connect the power line for bunn cwtf35 single coffee maker
  • 23 Answers
It is rather simple and color coded. On the machine there should be three wires behind the front panel which is held in by either 4 or 6 screws. Remove the panel, the wires are going to be black, red and white. In most instances the red and white are together. Simply hook up the black cord in the power cord to the black wire on the terminal. Then the white cord from the power to the red wire. The ground will go to a green screw with a flat plate which will be located at the bottom front of the tank. www.midstatebeverage.com
Posted on Nov 16, 2010
My Bunn model CWTF35-TS heats properly sometimes and is only luke warm other times! Just wondering what maybe causing this?
Defective temperature sensor is my guess, try running white vinegar through it a few times, the sensor may have hard water deposits on it which can alter the readings.
Aug 31, 2016 | Bunn Coffee Makers & Espresso Machines
How adjust water level on a bunn model cwtf35
If it is like the more expensive models you take the top off and there should be a rotary knob, if there is turn it just a little say maybe the thickness of a nickel. then brew a pot of water and check.
Oct 06, 2014 | Coffee Makers & Espresso Machines
Bunn coffee maker, no hot water
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Mar 16, 2013 | Bunn CWTF35
Machine overfilling
Sounds like the timer is not working correctly. Bunn carries a good supply of replacement parts.
Nov 09, 2009 | Bunn CWTF20-3 Automatic Coffee Brewer -...
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Jul 14, 2009 | Bunn CWTF35-3- Stainless Steel
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Dec 10, 2008 | Bunn NHB Coffee Maker
Bunn VPR Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Bunn Coffeemaker CWTF35-4
Hook it up to cold water. It has a heating element in the tank that heats the water.
Oct 24, 2007 | Bunn RL Coffee Maker
Bunn SINGLE, includes One 1 Gallon Server Logo
64 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
