Question about Compaq Computers & Internet
Won't start up, on/off button flickers then nothing happens. bought a new power lead but that doesn't seem to be the problem. help!
    Genius:
  • 1,066 Answers
Power button could be bad. you could try disconnecting the power switch from the motherboard, then manually shorting the motherboard power leads using a screwdriver or something. just short them for a brief moment, and the computer should start up.
Posted on May 17, 2008
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
Monitor won't switch on properly.
This is a common symptom of failing filter capacitors in the power supply board. Over time as the capacitors start to fail they are not able to buildup and hold a charge like they should. The worse they get the longer the start time will be until one day the unit will not start up at all. The repair is easy to do, it just requires replacing the 5 bad capacitors on the power supply board. Here is a link to a parts kit that shows what needs to be replaced on the board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=222
I hope this helps,
BuddyMc
Jul 19, 2012 | Samsung Computers & Internet
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop...
had a similar problem,and I resoleved it via a bios flash..this allowed the hardware to be fully recognized and to perform the specified role.For some reason,the bios software for this version seems to corrupt after several years. I have had my machine for the last four years..until it recently started giving the issues,it had no problems.
Jun 06, 2011 | HP Pavilion dv4000 Notebook
Computer Shutdown and Power light of the Cabinet Flickers Recently my computer is having a peculiar problem, while working on the computer it suddenly turn off and the blue power light of the cabinet...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Jun 03, 2011 | Intel Motherboard
Ihave a aopen computer. The other night when shutting down -- before the windows statement that it was ok to turn off the power. The lights on the power and reset lights flickered. I latter tried to power...
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 19, 2011 | Acer AOpen AX 6BC (91.87810.451)...
Hi, few days ago I bought a Netgear NAS 2110 and connected it to my Netgear WNDR3700 router. I installed RAIDar utility and followed the instructions. Everything seemed to work alright. From my laptop I...
If it's new it's probably doing some housekeeping. The drives need to be formatted and then the RAID arrays need to be sorted.
On installing my server, it took days to complete, however, that was with existing data on the drive.
It might not be letting you switch off because it's busy and doing so would mess up what it's trying to perform.
If you don't want to wait to find out if all is OK, go into the configuratio utility and set just one drive up. This will show if it's working as a unit. If all is fine, install the remaining drives, maybe one at a time.
Dec 30, 2010 | NetGear ReadyNAS Duo RND2110 NAS server...
Computers & Internet Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
