Question about Canon PowerShot Pro1 Digital Camera
SLR EOS 300D
I am having a big problem with this camera my images come out looking green on the PC and also have a green tinge when looking at them on the camera, please help as soon as possible as have a Wedding on Friday so getting very up tight.
Mike Grimes
    Genius:
  • 1,689 Answers
Check in the colour ballance setup. Read your instruction manual for details.
Jerry G.
Posted on Jul 07, 2008
Shutter stuck
this is a common problem with these models.. there is a oil that is sticking the shutter.. just take it to a local camera repair shop and they should fix it for about $50
Jul 21, 2012 | Canon EOS: D30 10D D60 300D SLR Di...
Windows 7 unable to recognize EOS 300D
Try using a card reader instead of the camera.
Oct 07, 2010 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My Digital Camera, EOS 300D, Digital Rebel EOS 5D is not compatible with my new Windows Vista. I can't download my images.
There are two was around this:
1) Get an external USB card reader - I recommend this, because it is faster and does not require any software updating
2) Download the latest EOS Utility from the Canon web site; you also need to download the latest drivers. The cameras you name are supported by Vista, but the original software isn't.
Jul 07, 2009 | Canon Digital Rebel / EOS-300D Digital...
I need a manual for my Canon EOS 300D SLR
FREE OF COST if u rate me FIXYA !!! here u go
http://support-asia.canon-asia.com/contents/ASIA/EN/0300110302.html
pls dont forget to rate me
Mar 21, 2009 | Canon Digital Rebel / EOS-300D Digital...
I have images on my card, but my Canon EOS Rebel 300D says "no images in the camera or card folder" how can I get them to download. Will they download at a Wal-Mart card reader?
look very carefully at the pins inside the socket.. you might have a bent or broken pin making the camera unable to read the card. Also, if the images on your card are not Jpg or CanonRAW, the camera won't recognize them.
Feb 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
MANUEL OR INSTRUCTION
This Product Model Code DS6041 is a Canon EOS D-SLR named either "Digital Rebel" or "300D Digital".
You may try these links:-
http://www.theusermanualsite.com/manuals/mfg/canon/eos_300d.html
or here
http://www.cleaningdigitalcameras.com/pdf/EOSDR300DIM-EN.pdf
I hope I can help you!
Feb 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon eos 300d - image to dark
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Jan 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 300D LCD monitor problem
turn off the camera.
remove the battery.
wait 10 seconds
replace the battery making sure the power is off.
then turn the power on.
that might reset the board.
otherwise, you might have arced the power if the unit was on when the battery was removed. if so, you have a service issue you can't fix on your own. refer to qualified servicer.
good luck
mark
Nov 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon PowerShot Pro1 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
