Question about Toyota Forklift Carburetorgas 5k 5f61018
The forklift engine stalls repeatedly when trying to operate at low idle even without a load on. toyota model # 2fg14
thutson66
  • 96 Answers
SOURCE: toyota forklift on propane
Sounds like the regulator is not opening up all the way or the air fuel mixture has been adjusted wrong
Posted on Aug 30, 2008
USfalcon
  • 175 Answers
SOURCE: Corolla repair manual
can y tell me what enigne size ?
Posted on Mar 23, 2009
MauiRentaCar
  • 288 Answers
SOURCE: 1994 toyota corolla has a runs rough at idle and
I have a similar problem with one of my Toyota Corollas. It's a 95 model with the 1.8L engine (7A-FE, automatic). But unlike yours, it has plenty of power while running. Here's what it does. Occasionally the engine misses. Sometimes it will die. This is most likely to happen when you start the car and put it in reverse and start rolling without giving the engine time to adjust. I've been told by some customers that it will die sometimes when coming to a stop. But this has never happened when I drive it. I don't think it's a fuel issue because the car runs just fine when it's running.
Here's what I've tried so far:
  1. Replaced spark plugs and wires.
  2. Used gasoline additive fuel injector cleaner.
  3. Checked air filter.
  4. Checked vacuum hoses for leaks.
  5. Replaced PCV valve and hoses.
  6. Cleaned the air intake and throttle body with carburetor cleaner.
So far there is no change in the problem.
What I plan to do next:
  1. Check the throttle position sensor.
  2. Check the MAF sensor.
  3. Adjust the idle via the set screw.
After that I have no idea what to do next if the problem persists. The check engine light is not on so I don't think there are any error codes. Will let you know.
Frank
Frank's Friendly Cars Maui Car Rental
www.MauiCarRental.biz
Posted on Aug 27, 2009
worriedtouch
  • 16 Answers
SOURCE: idle to low
The idle is electronic, possible causes of this could be the idle air control valve, mass air flow sensor, and air hose from filter. You can verify if there are any leaks in your filter housing with a visual inspection, you can also remove the mass air flow sensor very easily and see if it is clogged with dirt.
Posted on Aug 31, 2009
SOURCE: '03 Toyota Corolla 1,4 VVT-i 4ZZ engine idle rpm
Check your idle speed control valve situated at the bottom of the throttle body. Sometimes the valve sticks and will make the engine rev high or low at idle and the ECU can't adjust it properly.
Posted on Sep 09, 2010
Car will stall when ac turns on?
Given that the condition only occurs now when the AC is active, I would say the issue is likely with the AC. If the compressor is bad, or there is some other issue causing resistance with the AC system, it can really load the engine and drag it down. Also, the AC compressor uses a lot of electrical current which can load the system as well, making the engine work harder. Try disconnecting the connector to the AC compressor clutch and see if the problem still persists. If it goes away, you know your problem is with the AC system. Honestly, by the sound of things, you might be better off without the AC in that vehicle if that's what it comes to. AC systems are often more expensive than people expect to repair. Not to mention there are a lot of components to the system and you need specialized equipment, and sometimes a special license to work on it. For those reasons I don't recommend the DIY do AC work themselves. written by EricCG
press the helpful button and check links below
When is on car stalls at stop Toyota Nation Forum Toyota Car and Truck...
2001 corolla engine hesitates and sometimes dies Corollas
AE86 idling problem using the
Toyota Camry Stalls even while moving 1997 1998 1999 2000 2001
Feb 04, 2016 | Toyota Corolla Cars & Trucks
I got 1994 toyota andf it stall when i turn on anything like blinkers or headlight and when i put it in gear. Its a five speeed v-6 but it starts right up and idles but if i hit brake it sounds likeit
ok , i guess you are saying the engine stalls when I use heavy electrical loads (like head lamps or brakes or even blinkers)
and when you shift from park to drive.
ok , if the engine RPM is 800 before the stall, then that is a total loss
of engine power with lost of idle controls.
The big load is in DRIVE on automatics huge going to DRIVE.
if battery voltage (yes, a 10 buck walfart meter works) can see 13.3 to 15vdc idling at 800 or more RPm.
the Alternator does not work below 800 so , dont expect it to.
so, if rpm in park is below 800 then we fix that first, see why?
if idle drops below 800 this is caused buy many things.
one vital fact missing is you didnt say, if I drive it like a stole it.
that is aggressive right foot. , do you have full engine power, now?
ignoring stalls. (see my drift there, "is engine power good;?)
battery volts above 13.3vdc.
idle at 800 and stalls in DRIVE (shifted)
  • low fuel pressure.
  • never ever tuned up this decade, with all spark parts bad.
  • ISC stuck( idle speed controller (it lets in more air , in DRIVE)
  • low engine compression.
  • other complex ,fueling issues, (ask) and lots of tests. (ask)
if no tachmeter in car or tool box, repairs get dicey.
hard,
it takes tools to diagnose and fix cars.
go tools? or willing to buy them
if not,? get it serviced.
Dec 08, 2014 | 1994 Toyota Pickup
Stalling at low idle
I don't know this specific car. But, if it has one, check your Idle Air Valve. This can cause the engine to stall. If you can hold the gas pedal and the engine will continue to run until you let off the gas, it is likely the IAV. It will not necessarily cause the engine to run rough. That could be a number of things like spark plugs, wires or dirty injectors. It could also be a compression problem. Is the check engine light on?
Mar 04, 2014 | 1995 Dodge Intrepid
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
08 ss trailblazer stalls on take off
It can be low fuel pressure issue or clogged fuel pump.Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem :------
Thanks.
Nov 27, 2012 | 2008 Chevrolet Trailblazer
2002 toyota solara idles low and shuts off, engine was just replaced
Try this
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jul 03, 2012 | 2002 Toyota Camry Solara
Toyota 92 model no idle upon initial start up but idle when engine is warm
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
May 30, 2012 | 1992 Toyota Corolla
1998 Grand Marquis. Start goods. idols low. put in gear, stalls out. Changed fuel filter & had injectors serviced. Problem remains. Could it be the Transmission modulator valve?
I would check the operation of the idle speed control valve, it is what changes the idle speed when a load like the transmission is put on the engine, without it the engine will idle slow and stall out, this is even more apparent when reverse gear is selected or drive or the AC is tuned on. The ISC valve is located on the side of the throttle body top of upper intake manifold. Below is a picture of the ISC (idle speed control valve)
Sep 30, 2011 | 1998 Mercury Grand Marquis
Toyota forklift on propane
Aug 30, 2008 | 1995 Toyota Pickup
Toyota Forklift Carburetorgas 5k 5f61018 Logo
558 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
