Question about Trendware TRENDnet TE100-P1P 1-Port Parallel Print Server (S2109018) Print Server
Using a TE100-P1P/A print output is great except when printing from a purchased software package. When printing from this application the output is Extremely Slow in printing out. How can this be fixed?
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
Trendnet te100 HP P2035 not printing
1. What is the exact error message or error code?
2. Have you made any changes to the computer prior to this issue?
I would suggest you to refer the following Microsoft article and check if it helps.
Printer problems in Windows:
for more help visit CBR Tech Solutions
Apr 17, 2012 | Trendware TRENDnet TE100-P1U Print Server
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
Jun 24, 2010 | Trendware TRENDnet TE100-P11 Print Server...
I recently bought a MacBook and it won't connect wireless with my hp7580 all in one printer. The built in print server seems to work but I cannot install the printer in applications like Word. What to...
You have to actually install the HP printer software package. Even if you do have the CD that came with the printer, there's a good chance there's a newer version of the software at hp.com.
With Apple computers, adding software for peripherals is often not necessary, but the two common exceptions are with HP printers and all-in-one printers that have scanners. Some printers that have scanners won't work wirelessly at all, but the newer ones will, and sometimes they will print wirelessly but not scan wirelessly.
For audio and PA system expertise, and great AA Speaker Tapes, CDs and MP3 downloads, visit my website at www.rexark.com
Feb 24, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Jul 08, 2009 | Datacard SP25 Printer
Print Workshop 2008
Describe Your Problem:Please describe the problem to get it solved
I bought this print workshop 2007 since around November 2006. It work wonderful until January or February of this year. I rely deeply on this programme in which i used every week until this message below stop me.
I did reinstall this programme.Still will not work.
Same message.I did click the continue button but the programme will freeze.I will go crazy if this does not work for i need the programme for work.
The message is below.
An unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit, the application will be shut down immediately.
Exception has been thrown by the target of an invocation.
Aug 14, 2008 | ValuSoft Print Workshop 2003 for PC
Hp deskjet f380
To print from a software application (Windows)
1. Make sure you have paper loaded in the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the HP All-in-One is the selected printer.
4. If you need to change settings, click the button that opens the Properties dialog
box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Select the appropriate options for your print job by using the features available on
the various tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
Nov 08, 2007 | HP DeskJet F380 All-In-One Printer
610N dissapeared no lights, empty EIO, reset no help
If you're seeing it intermittently, try the following:
-remove it completely
-power cycle the printer with it out
-check your contacts (be sure no bent pins, etc)
-Try it in a different slot if you have one (most HP's with an internal jetdirect have 2-3 EIO slots, but since you don't mention what model printer you have I don't know for sure).
If it's not talking after all that, likely the jetdirect is actually dead. It's been known to happen. I wouldn't waste the money on a replacement, you'll have better luck getting an external card and it'll be cheaper, too.
HP sells both the JetDirect 170X and 175X externals; there's also the Linksys PSUS4, D-Link DP-300U, TrendNet TE100-P1P, or Netgear PS101NA. Price will vary between $45-80.
Mar 27, 2007 | HP JetDirect 610N Print Server
Trendware TRENDnet TE100-P1P 1-Port Parallel Print Server (S2109018) Print Server Logo
79 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
