Question about Frigidaire PLEF398AC Electric Kitchen Range
On my stove there is a red lock light that is on. Nothing will work. If I push any of the buttons nothing happens. Not sure what is going on
  • 2 more comments
  • troyb31 Sep 16, 2010
    its not a microwave its a frigidaire stove
    I got an anwer back on how to fix a microwave. I'm looking for an answer for a stove/oven. My stove top works just cant get the oven to work. It has a red lock light on. How do I unlock it.
    I have a frigidaire stove/oven. The stove is working fin. there is a red lock light on and I can not get the stove to work. None of the buttons are working.
  • troyb31 Sep 17, 2010
    My door is not locked. I can open the oven door. there is a red lock light under the digital clock. none of the electric buttons are working. I can not turn on the oven. The clock is not working. There is only a red lock light on
    Genius:
  • 1,035 Answers
Hi. Is there any Error code appears on the screen? Try this troubleshooting. Locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The locked light should disappear. If it is working, you'll hear a mechanical hum as it resets.
Posted on Sep 17, 2010
  • 3,083 Answers
This blog explains what is going on with your unit:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/7242-oven-door-wont-unlock.html
This link has some useful information:
http://www.appliance411.com/archive/24919_locking_mechanism_locked_wo_oven_door_closed.shtml
Pick your model number at the following site, and it will have diagrams that will help you:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PLEF398AC
Here is the link from the previous link:
http://www.appliance411.com/links/jump.cgi?ID=710
Good luck, hope this helps, and thanks for using FixYa.
    Genius:
  • 1,417 Answers
what this indicate is that there has been a loos of wire from the main power supply either from the wall or from the panel and it could also be from the fuse
here are the solutions to each likely problem .Carefully unscrew the screws at the back of the range then trace the wire connected to the wall down to the panel to see if there is any lose wire from it position then for the fuse
  1. Unplug your microwave. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  2. Locate the fuse. It should be near where the electrical cord comes into the microwave. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the microwave.
  3. Purchase a new fuse. Most range use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  4. Replace the fuse. Put the cover back on and see if your microwave works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced of Electric Kitchen Range repaired.
thank you and thanks for using fixya.
Posted on Sep 16, 2010
I have a 2007 ES 350. Changed key fob battery,now nothing works. Only immobilizer security light is flashing and engine start stop button has amber colored light on
Be sure to use the correct battery, properly in place, clean the key contacts , See owner's manual for additional information.
There are specialized locksmiths for car keys
Oct 02, 2014 | 2007 Lexus ES 350
I have a tappan self cleaning stove. I push the clean button and nothing happens. What am I doing wrong
Some have a "lock" switch that locks the door from opening. Most are located on the front of the oven door top. Moves over in the lock position, then hit the button. Hope that works
Sep 29, 2014 | Kitchen Ranges
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Won't turn on or up
Oeding,
The function Lock is ON. To turn it off push the v and ^ at the same time for 2 seconds. Then the stove should function normal.
Tom Hawkins
hawkins111@gci.net
Feb 21, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Dacor smooth cooktop lock light flashing... nothing works!
Hold the lock button down for 5 seconds to see if it will unlock
Jan 20, 2009 | Kenmore 78823 Gas Kitchen Range
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire PLEF398AC Electric Kitchen Range Logo
148 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
