Question about Ovens
I have a westinghouse saturn oven and the timer is on and i cant work out how to turn it off so the overn will work?
4 Suggested Answers
  • 215 Answers
SOURCE: westinghouse oven timer keeps turning the oven off
It sounds like the timer is set you will need to press the cancel/stop buttton, and this will clear the display.
Posted on Nov 15, 2009
SOURCE: Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
SOURCE: cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Posted on Jul 10, 2011
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
Westinghouse oven timer keeps turning the oven off
Nov 15, 2009 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ovens
Apr 20, 2009 | Ovens
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Cannot turn on Oven
your oven needs a new ignitor it has to draw 3 amps or more to open the gas valve (just because it glows doesnt mean its good) let me know how you make out
Feb 21, 2008 | Ovens
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Ovens Logo
179 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
