Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60PP9202 I replaced the IC's and my red convergence problem is totally gone but I still have a problem with the blue one.Could you possibly point me in the right direction?
    Genius:
  • Philips Master
  • 1,689 Answers
Check the electrolytic capacitors on the convergence board with an ESR meter for proper ESR. It is possible that there are some defective capacitors, and also other types of components that are part of the convergence system.
The set will most likely require some troubleshooting to determine the failed parts, if it is not a capacitor in the convergence area.
Jerry G.
Posted on May 21, 2008
I am able to adjust all the color convergences except red. Won't line up. Any helpful ideas would be appreciated. Also, if I have to replace an ic, typically how much does that tend to cost? Can I do it or...
The two convergence IC's need to be changed on the convergence board, and also check the low ohm resisters that might have change resistance on the convergence too. The red and blue should move up and down and left and right. The green is sationally.
Nov 11, 2010 | Philips 60PP9202 60" Rear Projection...
Where are the convergence chips located on my 60PP9202 for the red
There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 red shadow in the battom of the screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Philips 60PP9202 60" Rear Projection...
Blue convergance
Hi, convergence IC`s have failed,if you have soldering equip. and are proficient at soldering you can do the repair, if not call a tech, you will also have to do an alignment after replacing the stk`s, good luckk, video-tek
Feb 10, 2009 | Philips 60PP9202 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence problem
At present, bad connect(s) on red convergence IC. Soldering pins will fix temporarily.
Usual fix = replace STK392-110  IC's. A 400.00 dollar repair at
your local tv shop......T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
