Question about Freezers
Maytag side by side freezer leaking water and icing in bottom
My maytag freezer is icing up in the bottom and the leaks water out the door on the floor
  • 1 more comment
  • bkturner Jan 11, 2009
    I found this solution helpful. I followed the steps indicated and would just like to add that I think the root cause was the fact the
    manufacturer did not allow the water to drain via gravity to the tray. The drain tube actually sloped uphill. They had the drain tube screwed to the top panel of the liner which was higher than the drain elbow. Needless to say the water would sit in the tube and not drain to the tray thereby freezing inside the freezer. So I diconnected the screw holding the tube to the liner and trimed the drain end approximately one inch which allowed the tube to slope properly and now the water can drain directly to the tray. This should fix the problem.
  • Anonymous Mar 21, 2014
    frigidaire refrigerator 2 door side by side 26 cuft
  • Anonymous Mar 29, 2014
    leaking water from freezer into bottom of fridge.. how do you take it apart to fix drain
  • 828 Answers
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
Posted on May 17, 2008
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 | Freezers
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezers Logo
1,528 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
