Question about RCA RCR350 Remote Control
How do I re-program it so it works???? - RCA RCR350 Remote Control
  • 122 Answers
I assume you need the user manual and code list?
RCA RCR350 Manual & Code list
Posted on Sep 16, 2010
How do I program the remote?
to program a fob key to an immobiliser you should take it with the vehicle to the service dealer and have it programmed properly
however that will cost more than what the locksmith is charging
best is to get him to program it and if it doesn't work then don't pay him because the price will include supply, cut and program
Jun 05, 2015 | 2007 Mitsubishi Raider LS
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
I am missing some files and can not uninstall program to reinstall. I go to add and remove programs. I am trying to reinstall the program but it tells me I already have installed it
Try going to the program's directory and run the uninstall from there. Your program is likely at c:\program files\<program> where <program> is the name of the program or the manufacturer of the program. Try executing the file 'uninstall'. It might do better.
If it doesn't work any better than add/remove programs, you may have to become a bit more creative.
May 25, 2010 | Microsoft Computers & Internet
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
123CopyDVD.exe has stopped working......
First, Uninstall your program using Add/Remove Program in Control Panel.
Start Menu -> Control Panel -> Add/Remove Programs
Note: Be aware of shared files don't remove them, it will affect other programs that use that file
After Uninstall, restart your computer
Then start again, proceed to installation of your program.
Jan 26, 2010 | Navarre 123 Copy Dvd Gold for PC
Can only program one remote or keypad. which ever
You are going to have to do a process of elimination. I think you have either a bad remote or a bad keypad. Try programming a remote and then the keypad. If only one works then go with the other remote and the keypad. If only one works then program the two remotes. If the two remotes work then the keypad is bad or if you can program one remote and the keypad then the other remote is bad. Get rid of the bad one.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
Aspire 5610-2762 Orbicam not working
plz try by reloading the webcam software if you have webcam
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Vista programs that work and don't work
List of compatible hardware and software
Some of your XP programs may need to be upgraded to work with Vista.
May 17, 2008 | HP Pavilion dv6000z Notebook
RCA RCR350 Remote Control Logo
580 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
