Question about Maytag Neptune FAV6800AW Top Load Washer
It goes off balance in the reverse cylce. I just put a new clutch in.
  • 526 Answers
"" it goes off balance in the reverse cylce. I just put a new clutch in. ""
Is that the Spin Cycle? Wash basket is rotating CCW is that correct?
Did you follow this post for the Clutch replacement?
I
Posted on Sep 19, 2010
1997 rodeo 4x4 4l60e transmission is loud, goes in drive when revved high and goes in reverse perfect. What could the problem be?
You have a sprag (over running one way clutch) that is not working properly, or a support bearing that is shot and causing one clutch to put preasure on another and trying to engage it also
it is time for a rebuild or new trans
Mar 29, 2015 | 1997 Isuzu Rodeo
2002 isuzu axiom won't move when put in drive or reverse
ur linkage come un clipped from the rod that goes into the transmission or ur bands need adjusted if its a clutch bleed the clutch
Feb 27, 2013 | 2003 Isuzu Axiom
Suzuki won"t shift into gear unless I turn the car off and put it into first
make your adjustment to clutch, see how that works, but start saving up for a new clutch, or just have your inspection mechanic, take a look @ it for you, make the adjustment, and he can remove a cover and inspect the condition of your clutch with his own eyes. its a lot easyier for him than you. then, you'll know for sure. good luck
Jan 13, 2013 | 2001 Suzuki Grand Vitara
My 99 camry only goes in reverse, what's wrong?
its your clutch its gone change it and tell me the new results change the clutch kit
Dec 04, 2012 | Cars & Trucks
Hi, You assisted me before on the same vehicle. I installed my new transmission system and have been driving it for a couple of month now. The issue is a Vibration when I first release the clutch in 1st...
The last time I felt vibration in the pedal like that I had a broken clutch finger. I would hate to tell you to take it all out again only to find no broken fingers. I've also seen vibration from improper mating of the friction disc and flywheel. It'll wear on the inside of the flywheel before it wears on the outside and thus you feel that as a vibration. But, it is most likely the clutch plate isn't balanced right. Just to be sure, take a look at the harmonic balancer to make sure it is still one piece and the rubber isn't coming out. It can dampen out most vibrations like this but can only do so much. But, if it is compromised in some way, even small vibrations can get through. Also, did you install a new pilot bushing when you did the clutch? Fixya is discontinuing this service soon and they say they have plans to come up with something new. I'm not supposed to share contact information here per terms of service, but there is no reason you can't Google 'ZX2Fast' now is there? If you need more help and can't get to me from here, just Google me and I'm sure you can find some way of asking for help. Oh yeah, you should also inspect all of your engine and transmission mounts. You would feel vibration if you have a broken mount and the engine/transmission was resting against metal.
Feb 11, 2012 | Cars & Trucks
I have a 1997 Pontiac Sunfire that has problems shifting into gear. (manual trany). Have to force into 1st, 3rd, 4th, 5th and especially in reverse. Will grind going into reverse. Have to turn off...
Sounds like the clutch is going out. I would check the operation of the clutch slave cylinder. Also check the clutch master cylinder fluid level.
Oct 18, 2010 | 1997 Pontiac Sunfire
Have a 94 New Yorker when I put it in reverse I get a red R on the PRNDL and don't have reverse all other gears are green and work. What might be causing this?
the reverse clutch in the trans is after failing.there are two clutch packs in trans for reverse,low/reverse and reverse clutch in overdrive unit,so where you have all foward gears the low/ reverse is ok the reverse clutch in od unit is most likely culpret
Aug 08, 2009 | 1994 Chrysler New Yorker
Truck wont move in gear [manual trans] why?
push the clutch pedal all the way and see if the slave cylinder pushrod is going out at least an inch, if not replace the slave cylinder, if it does goes out, sad to say but you have problem somewhere else inside your clutch assembly
Jan 28, 2009 | 1990 Toyota 4Runner
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
