Question about Kitchen Ranges
I am looking for the service manual for the Model D Bendix automatic ironer from the 1950's.I need to replace oil that leaked out during transit.
    President:
  • 2,777 Answers
It is going to be virtually impossible to find that service manual for your Bendix ironer... They aren't available in electronic format, and never have been, you'd have to find someone with a paper copy just laying around they were willing to give you. You will have better luck just replacing the unit all-together, I know I saw a Bendix automatic ironer a few weeks back for $40 at a pawn type shop... You may have to keep searching ebay or something similar to find one... but to find the manual is virtually impossible.
Sorry about that,
Tim
Posted on Sep 16, 2010
What services are performed during the 1st scheduled maintenance?
Look in your wallet that has the manual and the radio instructions. you will also find a Warranty booklet and in there all the service schedules.
You can log in find out here.
http://owners.honda.com/service-maintenance/minder?year=2015&model=Odyssey
This is what is covered
B
Replace engine oil and oil filter
  • Engine oil capacity with oil filter: 4.3 L (4.5 US qt)
Check front and rear brakes
  • Check pads and discs for wear (thickness), damage, and cracks.
  • Check calipers for damage, leaks, and tightness of mounting bolts.
  • Check parking brake linings for cracking, glazing, wear, and for oil or grease contamination.
Check parking brake adjustment
  • Check the number of clicks (8 to 10) when parking brake pedal is pressed with 294 N (30.0 kgf, 66.1 lbf) of force.
Inspect tie-rod ends, steering gearbox, and gearbox boots
  • Check steering linkage.
  • Check boots for damage and leaking grease.
  • Check fluid lines for damage or leaks.
Inspect suspension components
  • Check bolts for tightness.
  • Check condition of ball joint boots for deterioration and damage.
  • Front
  • Rear
Inspect driveshaft boots
  • Check boots for cracks and boot bands for tightness.
Inspect brake hoses and lines including VSA lines
  • Check master cylinder and VSA modulator-control unit for damage and leakage.
Inspect all fluid levels and condition of fluids
Check levels and check for leaks. If necessary, add:
  • Engine coolant
  • Automatic transmission fluid
    • 5-speed
    • 6-speed
  • Power steering fluid
  • Brake fluid
  • Windshield washer fluid
Inspect exhaust system*
  • Check catalytic converter heat shields, exhaust pipe, and muffler for damage, leaks, and tightness.
Inspect fuel lines*, and connections*
  • Check for loose connections, cracks, and deterioration; retighten loose connections and replace damaged parts.
Maintenance Minder Maintenance Schedule Honda Owners Site
Jan 01, 2016 | 2015 Honda Odyssey
Breville VIN 214 iron leaking - can anyone help please
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
Manual for Bissell quicksteamer.
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell QUICKSTEAMER 1950 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 19, 2012 | Vacuums
I have 2 larger f series ford diesels. Both have the Bendix Convac vacuum pump, both are broken/leaking oil. Neither truck needs vacuum to assist the brakes (1 air brakes, 1 hydromax assist) but both...
When you say airbrakes, do you mean that the vehicle has airbrakes, or does it have hydraulic brakes with a vacuum brake booster? As far as replacing it with a 12v vac pump, there might be some DOT regulations prohibiting this as it involves safety issues. If one has the vac booster, it is leaking brake fluid and not oil. The hydrovac booster will leak either as it uses power steering fluid from the P/S pump to do the job.
Feb 28, 2011 | 1999 Ford Super Duty F 450
I have got DWN 38 L Bendix dishwasher, problem is that during the wash cycle water starts to come under the washer. To ,me it looks like it can't take the water out.
If water is collecting under the dishwasher then there could be a few reasons.
1. door gasket is leaking - check for defect and replace if required
2. the wash or drain pump could be leaking water. Seals are not sitting properly or drain hose is cracked.
Feb 15, 2011 | Tricity Bendix 24 in. DH104 Free-Standing...
JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Mar 21, 2009 | John Deere Garden
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
