Question about Panasonic DMR-E50 DVD Recorder
Recently, I've been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as I have done for many years. However, lately, whenever I would program it to record a tv program using the timer programming, it would come on and immediately stop, appearing to be frozen. When I would try to turn the system on, it would not respond to the remote or power button on the system. I would have to unplug it, wait a couple of minutes, then plug it back in. It would come on and the "Recovery" message would appear. I tried a new DVD-RAM disk (the kind I've always used) with the same result. I then tried formatting the new disk. Formatting was successful, but when I tried to record on it, I got a message that the disk was not recordable. I tried another new DVD-RAM disk. The machine recorded as programmed, but will not play the recorded programs. When I try to play the recorded programs, I get an error message that the disk is unformatted. However, when I try to format the disk I get another error message saying that the disk is unformattable. Is my machine simply worn out or can it be fixed? Please help.
  • epona275 Sep 21, 2010
    The first expert's response makes little sense to me. I am not an expert technician, just a home user. Thanks.
  • epona275 Oct 22, 2010
    Thanks so much!
  • Panasonic Master
  • 12,061 Answers
Hi, I see similar one a lot in my shop, what has happened is your laser head assembly, and or quadrant detector has gone faulty, this is just so common. To make it work properly again you will need to replace these faulty parts. This can be an expensive repair depending on the cost of the laser head assembly, and labor.
What you need to do is take it to an authorised Panasonic repair agent, and ask them for a "Quote" for the repair. This way you can make a decision as to repair or replace.
Posted on Sep 22, 2010
  • Panasonic Master
  • 17,130 Answers
Seems that you have done the best and nothing more to confirm the limits of a DIY job. It seems to me that the memory back or the micro processor/ inferface has errros that have crepted in with wrong compatibility, the reason that the set hang up with a slight provocation.
You can remove and push back plugs, tighten cords, look for any breach of contacts or pasive components.
I seems that possibilities in the mother board are many and can be relative except if we can swap a new board to test..
Posted on Sep 21, 2010
Hallo, I'm new here, I hope someone can help me with my problem. I have a Panasonic DMR-HS2 DVD recorder, and I've had no problems yet, till recently. I had programmed several TV programs. W
It might well have crashed!
I suggest you unplug or turn off the power to the unit and leave it off for a while to see if it corrects itself when you power up again.
Keep a look out for any codes in the display when it powers up. Was there a disc in the drive when you shut it down? That might be contributing to the problem if there is.
If the hard drive has failed it still might be possible to remove it and recover the contents, before fitting a new one. There are the same ones you buy for home PC's afterall.
Mar 08, 2017 | Panasonic DMR-HS2 DVD Recorder
I've worn out the remote control for my Pansons DVD video recorder DMR-E50. Please tell me how I can get another one. Thanks.
Here is a link to one available for $35.95
http://www.dvdremotecontrols.com/Mfrs/Panasonic/MscDVD/EUR7615KN0.htm
And one for $34.95
http://www.remotecontrolwarehouse.com/PANASONIC/EUR7615KN0.html
Your other option is to buy a Universal remote that can work with your DVD recorder. The one from the Panasonic website is about $50
Jan 11, 2010 | Panasonic DMR-E50 DVD Recorder
Machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Nov 16, 2009 | Panasonic DMR-E50 DVD Recorder
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Bubble console code for panasonic dmr e50 dvd recorder
hi have seen your plight i have a booklet with codes as panasonic codes 2017 1990 1986 1925 1910 1909 1908 1907 1905 1762 1490 1462 1362 1011 1010 0824 0703 0632 0503 0490 good luck
Aug 31, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic
There is a manual for a E50S and a E50K. Could one of these be yours? One might be close enough to help. Go here
http://www2.panasonic.com/consumer-electronics/support/
Aug 08, 2008 | Panasonic DMR-E50 DVD Recorder
PANASONIC DMR-E50
service.us.panasonic.com/OPERMANPDF/DMRE50.PDF
Apr 08, 2008 | Panasonic DMR-E50 DVD Recorder
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
Dec 29, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
