Question about Garden
How to replace purge bulb on a echo chain saw cs-3000
  • valleygrovel Sep 17, 2010
    It has no bolts or screws it is in the top of the case i thany it has a rubber gromit around it.I can not get the gromit out.
  • 1,041 Answers
Once you are able to get to the four screws holding the primer bulb on, simply remove the screws, grab the bulb and pull off of carburetor. Take the metal sleeve off of old bulb and replace with the new one. Reverse procedure and GO CRAZY!
If I can help you any further, let me know.
JIm
Posted on Sep 16, 2010
  • Jim Parker
    Jim Parker Sep 17, 2010
    Here is a link to your carburetor (cs-3000 Type 1E)?:
    www.partstree.com/parts/?lc=echo&mn=CS-3000+Type+1+S%2FN+001001_Up&dn=5277
    You will have to copy and paste this link.
    This should help, Let me know.
    Jim
  • Jim Parker
    Here is a link to your manual:
    www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
2 Suggested Answers
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
How do I replace the purge pump on thr Echo chain saw model CS 3000
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I change the primer bulb on my Echo CS-3000 chain saw
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Sep 06, 2009 | Echo Garden
Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Jan 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
289 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
